Show that ## 2^{n} ## divides an integer ## N ##.
  • Thread starter Thread starter Math100
    Integer
The discussion focuses on proving that an integer N is divisible by \(2^n\) if and only if the number formed by its last n digits is also divisible by \(2^n\). The proof begins by expressing N in terms of its decimal representation and analyzing the divisibility conditions based on the properties of powers of 10. Participants highlight the need for clarity in variable definitions and address counting errors in the proof. The conversation emphasizes the importance of proving both directions of the equivalence, suggesting that an inductive approach may be suitable for larger values of n. The overall conclusion is that the last n digits determine the divisibility of N by \(2^n\).
Math100
Show that ## 2^{n} ## divides an integer ## N ## if and only if ## 2^{n} ## divides the number made up of the last ## n ## digits of ## N ##.
[Hint: ## 10^{k}=2^{k} 5^{k}\equiv 0\pmod {2^{n}} ## for ## k\geq n ##.]
None.
Proof:
Suppose ## 2^{n} ## divides an integer ## N ##.
Let ## N=a_{m}10^{m}+a_{m-1}10^{m-1}+\dotsb +a_{1}10+a_{0} ## for ## 0\leq a_{k}\leq 9 ##.
Then ## 2^{n}\mid N\implies 2^{n}\mid (a_{m}10^{m}+a_{m-1}10^{m-1}+\dotsb +a_{1}10+a_{0}) ##.
Note that ## 10^{k}=2^{k} 5^{k}\equiv 0\pmod {2^{n}} ## for ## k\geq n ##.
This means ## 2^{n}\mid 10^{n}\implies 2^{n}\mid (2^{n} 5^{n}) ##.
Thus
\begin{align*}
&2^{n}\mid [10^{n}(a_{n+i}10^{i}+\dotsb +a_{n}]\\
&2^{n}\mid (a_{n+i}10^{n+i}+\dotsb +a_{n}10^{n})\\
&2^{n}\mid (a_{n-1}10^{n-1}+\dotsb +a_{0}).\\
\end{align*}
Conversely, suppose ## 2^{n} ## divides the number made up of the last ## n ## digits of ## N ##.
Then ## 2^{n}\mid (a_{n-1}10^{n-1}+\dotsb +a_{0}) ##.
This means ## a_{n+i}10^{n+i}+\dotsb +a_{n}10^{n}=10^{n}(a_{n+j}10^{j}+\dotsb +a_{n})=2^{n} 5^{n}(a_{n+j}10^{j}+\dotsb +a_{n}) ##.
Thus
\begin{align*}
&2^{n}\mid (a_{n+i}10^{n+i}+\dotsb +a_{n-1}10^{n-1}+\dotsb +a_{n}10^{n})\\
&2^{n}\mid N.\\
\end{align*}
Therefore, ## 2^{n} ## divides an integer ## N ## if and only if ## 2^{n} ## divides the number made up of the last ## n ## digits of ## N ##.
How do we know that ##N## has ##n## digits? ##2^3\,|\,16## but ##16## has only ##2## digits. How can your criteria be an equivalence?
Let us assume ##N## has ##m## digits and ##n\leq m.##
Math100 said:
Thus
\begin{align*}
\end{align*}
Here, I got lost. What is i? You have to define the variables that you use. You also made a counting error.
We have ##m\geq n## and also ##2^m\geq 2^n.## Now ##N= (a_{m}10^{m}+a_{m-1}10^{m-1}+\dotsb +a_{n+1}10^{n+1}+a_n 10^n)+(a_{n-1}10^{n-1}+a_{n-2}10^{n-2}+\dotsb +a_{1}10+a_{0}).## From ##2^{m}\geq 2^n## we get ##2^n\,|\,10^n,10^{n+1},10^{n+2},\ldots,10^m## so ##N\equiv (a_{n}10^{n}+a_{n-1}10^{n-1}+\dotsb +a_{1}10+a_{0}) \pmod{2^n}.##
This is already what we have to show.
Remark:
If ##2^n\,|\,N## then ##0\equiv N\equiv (a_{n}10^{n}+a_{n-1}10^{n-1}+\dotsb +a_{1}10+a_{0}) \pmod{2^n}.##
If ##2^n\,|\, (a_{n}10^{n}+a_{n-1}10^{n-1}+\dotsb +a_{1}10+a_{0}) \pmod{2^n}## then ##N\equiv (a_{n}10^{n}+a_{n-1}10^{n-1}+\dotsb +a_{1}10+a_{0}) \equiv 0 \pmod{2^n}.##
The zero is on the left in one direction and on the right in the other direction.
Thus
\begin{align*}
&2^{n}\mid N.\\
\end{align*}
Likes Math100
Let us assume ##N## has ##m## digits and ##n\leq m.##Here, I got lost. What is i? You have to define the variables that you use. You also made a counting error.
Remark:
I forgot to quantify the variable ## i ##.
I assume ##m=n+i## and ##j=i.## It was already late over here and I'm a bit tired. Guess I have been a bit harsher than necessary, sorry. Your proof looks ok except for the counting error. The last ##n## digits are ##a_{n-1},a_{n-2},\ldots,a_1,a_0.##
Likes Math100
@Math100, here are some ideas to think about.
If n = 1, ##2^n = 2^1 = 2## has to divide only the last digit, call it ##d_0##. That's trivial, since if 2 divides the last digit, the number N is even.
If n = 2, ##2^n = 2^2 = 4## has to divide the last two digits, ##d_1d_0##. This means that ##d^2##, if there is such a digit in N, is in the hundreds' place. 4 divides ##d_2 \times 100##, so if 4 also divides ##d_1d_0##, 4 also divides N.
And so on, which I leave to you. Each larger value of n corresponds to a higher power of 10, which has another factor of 2. A proof by induction might be appropriate here.
Keep in mind that this is an "if and only if" type of proof, so you have to also prove the converse. I.e., you need to prove that if ##2^n## divides the last n digits of N, then ##2^n## divides N, and if ##2^n## divides N, then ##2^n## divides the last n digits of N.
Remark:
But for the second part of the proof which starts with 'Conversely...', how should I prove this? Starting out with ## 2^{n}\mid (a_{n}10^{n}+a_{n-1}10^{n-1}+\dotsb +a_{1}10+a_{0})\pmod {2^{n}} ##. At first, I thought that using the hint would be easier but you said that there are counting errors.
Your error is that you wrote ##a_n## but it should be ##a_{n-1}##.
$$|\{a_0,a_1,a_2,\ldots,a_{n-2},a_{n-1},a_n\}|=n+1\quad \; , \;\quad |\{a_0,a_1,a_2,\ldots,a_{n-2},a_{n-1}\}|=n$$
##n## digits means to stop at ##n-1## since we started counting at ##0.##
Likes Math100
