Show that acceleration varies as cube of the distance given
chwala
See attached.
Rate of change
In my approach i have distance as ##(x)## and velocity as ##(x^{'})##, then,
##(x^{'}) = kx^2##
where ##k## is a constant, then acceleration is given by,
##(x^{''}) = 2k(x) (x^{'})##
##(x^{''}) = 2k(x)(kx^2) ##
##(x^{''}) = 2k^2x^3##.
Correct?
It seems OK.
Thread 'Use greedy vertex coloring algorithm to prove the upper bound of χ'
Hi! I am struggling with the exercise I mentioned under "Homework statement". The exercise is about a specific "greedy vertex coloring algorithm". One definition (which matches what my book uses) can be found here: https://people.cs.uchicago.edu/~laci/HANDOUTS/greedycoloring.pdf Here is also a screenshot of the relevant parts of the linked PDF, i.e. the def. of the algorithm: Sadly I don't have much to show as far as a solution attempt goes, as I am stuck on how to proceed. I thought...
