Show that an expected value of a vacuum state is equal to 1
mcas
Using the following anticommutator relations of fermionic one-particle operators:
[itex]\{\hat{c}_{k\alpha},\hat{c}_{k'\beta} \}= \{ \hat{c}^\dagger_{k\alpha}, \hat{c}^\dagger_{k'\beta} \} = 0[/itex]
[itex]\{\hat{c}_{k\alpha},\hat{c}^\dagger_{k'\beta} \}=\delta_{kk'}\delta_{\alpha\beta}[/itex]
Show that the expected value for a vacuum state [itex]|\phi_0>[/itex] is:
[itex] <\phi_0| \hat{c}_{-k \downarrow} \hat{c}_{k \uparrow}\hat{c}^\dagger_{k \uparrow}\hat{c}_{-k \downarrow}|\phi_0>=1
[/itex]
Given in the homework statement
<br /> \langle \phi_0| \hat{c}_{-k \downarrow} \hat{c}_{k \uparrow}\hat{c}^\dagger_{k \uparrow}\hat{c}_{-k \downarrow}|\phi_0\rangle = \\ \langle \phi_0| - \hat{c}_{k \uparrow} \hat{c}_{-k \downarrow} \hat{c}^\dagger_{k \uparrow}\hat{c}_{-k \downarrow}|\phi_0\rangle = \\ \langle \phi_0| \hat{c}_{k \uparrow} \hat{c}^\dagger_{k \uparrow} \hat{c}_{-k \downarrow}\hat{c}_{-k \downarrow}|\phi_0\rangle = \\ \langle \phi_0|(1- \hat{c}^\dagger_{k \uparrow} \hat{c}_{k \uparrow} ) \hat{c}_{-k \downarrow}\hat{c}_{-k \downarrow}|\phi_0\rangle = \\ \langle \phi_0|\hat{c}_{-k \downarrow}\hat{c}_{-k \downarrow}|\phi_0\rangle - \langle \phi_0|\hat{c}^\dagger_{k \uparrow} \hat{c}_{k \uparrow} \hat{c}_{-k \downarrow}\hat{c}_{-k \downarrow}|\phi_0\rangle<br />
Then I changed \hat{c}^\dagger_{k \uparrow} \hat{c}_{k \uparrow} in the second term to (1- \hat{c}^\dagger_{k \uparrow} \hat{c}_{k \uparrow} ) and the result was \langle \phi_0| \hat{c}_{-k \downarrow} \hat{c}_{k \uparrow}\hat{c}^\dagger_{k \uparrow}\hat{c}_{-k \downarrow}|\phi_0\rangle which is exactly what I sarted from.
I don't know where to go from this so I would really appreciate any help!
Where did you get this problem from?
Are the ##\hat{c}_{k\alpha}## usual annihilation operators?
How is the ##\ket{\phi_0}## state defined?
If ##\ket{\phi_0}## is the usual vacuum defined from the ##\hat{c}## operators then, if I'm not wrong, by definition ##\hat{c}_{-k \downarrow} \ket{\phi_0}=0## and the whole expectation value vanishes. So, either I'm confused by something, or the problem is wrong, or you have extra information that is crucial for solving the problem.
Likes mcas and anuttarasammyak
It's a problem formulated by my professor.
After you post I contacted him and indeed, he made a mistake in the homework statement, as the last operator \hat{c}_{-k \downarrow} should be conjugated for the expected value to be one. In the original statement, the value will be 0.
Thank you!
