MHB Show that diagonals in a diamond (rhombus) are orthogonal
The discussion focuses on proving that the diagonals of a rhombus are orthogonal. Participants clarify that the dot product of the diagonals, represented as AC and BD, equals zero, indicating orthogonality. A key point made is that in a rhombus, the lengths of adjacent sides (AB and AD) are equal, which simplifies the calculations. The conversation also highlights the use of vector notation to illustrate the relationships between the sides and diagonals. Ultimately, the proof demonstrates that the diagonals intersect at right angles.
Petrus
Hello MHB,
I am working with a exemple that I think they got some incorrect.
Exemple 10.Show that diagonals in a diamond(romb) is orthogonal.
I understand that $$AC•BD=0$$ cause of dot product and if it's orthogonal the angle is $$\frac{\pi}{2}$$
I understand all the part until the step before the last one
Edit: last part got cut in picture, it should be: $$|BC|^2-|AB|^2=0$$
Regards,
$$|\pi\rangle$$
Mathematics news on Phys.org
Re: Show that diagonala in a diamond(romb) is orthogonal
Are you talking about how:
$$\overline{AB}\cdot\left(\overline{AD}-\overline{BC} \right)=0$$ ?
If so, this is because:
$$\overline{AD}=\overline{BC}$$
Hello Mark!
Thanks for the fast respond! Now evrything make sense! I did confuse myself and thought they did rewrite $$AB•AD=AB•(AD-BC)$$ but they did rewrite $$AB•AD-BC•AB=AB(AD-BC)$$ and indeed $$AD=BC$$ so we could also rewrite that as $$AB(BC-BC)$$ or $$AB(AD-AD)$$. I did not see that.. Thanks a lot evrything make sense now!
Regards,
$$|\pi\rangle$$
Petrus said:
Hello MHB,
There is little new in my post except to point out some advantages of vector notation.
Use \overrightarrow {AB} as the vector from A to B and \|\overrightarrow {AB}\| as the length of the vector.
Now if \overrightarrow {AB} ~\&~\overrightarrow {AD} are adjacent sides of a convex quadrilateral, then the diagonals are \overrightarrow {AB}+\overrightarrow {AD}~\&~\overrightarrow {AB}-\overrightarrow {AD}.
Note that \left( {\overrightarrow {AB} + \overrightarrow {AD} } \right) \cdot \left( {\overrightarrow {AB} - \overrightarrow {AD} } \right) = {\left\| {\overrightarrow {AB} } \right\|^2} - {\left\| {\overrightarrow {AD} } \right\|^2}.
But in a rhombus those two sides are equal length, giving us zero.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Is it possible to arrange six pencils such that each one touches the other five? If so, how? This is an adaption of a Martin Gardner puzzle only I changed it from cigarettes to pencils and left out the clues because PF folks don’t need clues. From the book “My Best Mathematical and Logic Puzzles”. Dover, 1994.
