- #36
- 23,358
- 5,727
This is correct. There is a mechanistic difference between free expansion of an ideal (compressible) gas and the example I gave of doing work on an incompressible liquid. But viscous dissipation plays a role in both cases.Philip Koeck said:I've started thinking about the mechanism of entropy generation in your example and also for free expansion.
In your example the upper plate is moved against the friction due to the viscosity of the liquid. The work that's done is converted to inner energy and increases the temperature of the liquid and generates entropy.
An ideal gas is the limiting case of a real gas at low density, and, even at low density, there are significant numbers of collisions between molecules. (For example, check out the mean free path of air molecules at 1 bar, clearly in the ideal gas region). It is collisions and associated energy transfer between molecules that are responsible for viscous effects. So even an ideal gas exhibits viscous dissipation and is not inviscid. See Bird, Stewart, and Lightfoot for a graph showing the viscosity of gases in the ideal gas limit.In free expansion there's no work being done from the outside, no heat is transferred.
The average kinetic energy of these molecules is unchanged since the inner energy is constant (at least for an ideal gas).
When the gas expands it does no work on the surroundings.
The only thing that really happens is that molecules fly around chaotically and move further from each other.
For a real gas there's also viscous friction between the molecules, is that right?
As I said, even for an ideal gas there is viscous friction. In the case of free expansion of an ideal gas, even though the gas does no work on its container, the parcels of gas still expand against each other, and this would ordinarily result in expansion cooling. However, because of viscous dissipation in the gas, the expansion cooling is exactly canceled by viscous heating, so there is no net effect on the internal energy of the gas and its temperature. And the viscous heating is ultimately responsible for the entropy increase (since no entropy enters the gas through the insulated boundary of the container).For an ideal gas: There is no potential energy and also no friction between the molecules. The only reason I can see for the entropy increase is the expansion.
