MHB Show that f'(0) exists and find its value
  • Thread starter Thread starter evinda
    Value
The discussion centers on proving the existence of the derivative f'(0) for a function f that is continuous at 0, given the limit condition involving f(x) and f(tx). Participants explore different approaches, including using L'Hôpital's rule and the mean value theorem, to derive that f'(0) equals b/(1-t). However, it is emphasized that the differentiability of f at 0 must be established first, as the initial conditions only guarantee continuity at that point. Ultimately, the conclusion is that f'(0) exists and is indeed equal to b/(1-t), provided the necessary conditions are met.
evinda
MHB
Hello! :D
I am looking at this exercise:
Let f: (-a,a)\rightarrow \mathbb{R} continuous at 0.We suppose that for a t \epsilon (0,1) this condition is satisfied:
\lim_{x\rightarrow 0}\frac{f(x)-f(tx)}{x}=b
Show that f'(0) exists and find its value.
I thought that I could write it like that \lim_{x\rightarrow 0}\frac{f(x)-f(0)+f(0)-f(tx)}{x}=b \Rightarrow \lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x}+\lim_{x\rightarrow 0}\frac{f(0)-f(tx)}{x}=b\Rightarrow (1-\frac{1}{t})\lim_{x\rightarrow 0}\frac{f(x)-f(0)}{x}=b
So,f'(0) exists and is equal to \frac{bt}{t-1} .Are my thoughts right or am I wrong?
If the first derivative exists at $0$ then by L'Hosiptal rule we have
$$ \lim_{x\rightarrow 0}\frac{f(x)-f(tx)}{x}= f'(0)-tf'(0) = b $$
$$f'(0)= \frac{b}{1-t}$$
And that is the only thing I have to say?So...because of the fact that $$ \frac{b}{1-t}\epsilon \mathbb{R}$$ ,$$ f'(0) $$ exists,and its value is $$ \frac{b}{1-t} $$ ?
evinda said:
Hello! :D
The mean value theorem extablishes that, given a function f(*) continuous in [a,b] and differentiable in (a,b), it exists a number c in (a,b) such that... $\displaystyle f^{\ '} (c) = \frac{f(b) - f(a)} {b - a}\ (1)$
Setting in (1) b=x and a= t x, if ...
$\displaystyle \lim_{ x \rightarrow 0} \frac{f(x) - f(t\ x)}{x} = \alpha\ (2)$
... is also...
$\displaystyle \lim_{ x \rightarrow 0} \frac{f(x) - f(t\ x)}{x\ (1 - t)} = \frac{\alpha}{1 - t} = f^{\ '}(0)\ (3)$
Merry Christmas from Serbia
$\chi$ $\sigma$
... is also...
And which interval [a,b] do we take??
If You chose a= t x and b = x, then b-a = x (1 - t) and t x < c < x. If x tends to 0, then a, b and c tend to 0 and starting from...
$\displaystyle \lim_{x \rightarrow 0} \frac{f(x) - f(t\ x)}{x} = \alpha\ (1)$
... You arrive at...
$\displaystyle f^{\ '} (0) = \frac{\alpha}{1 - t}\ (2)$
$\chi$ $\sigma$
And [a,b]=[tx,x] should be \subseteq (-a,a) .Right?
So,can I start like that:f is continuous in [a,b]\subseteq (-a,a) and differentiable in (a,b),so it exists a number c in (a,b) such that f&#039;(c)=\frac{f(b)-f(a)}{b-a}.
We select a=tx and b=x . ?
Show that f&#039;(0) exists and find its value.
ZaidAlyafey's comment shows that if $f'(0)$ exists then it is equal to $\dfrac b{1-t}.$ The snag with this, and with all the other comments, is that you are not told that $f$ is differentiable. You are not even told that it is continuous, except at the single point $0$. So you cannot use l'Hôpital's rule, or the mean value theorem, or any other result that requires differentiability, and you need to prove that $f$ is differentiable at $0$.
You are told that \lim_{x\rightarrow 0}\frac{f(x)-f(tx)}{x}=b. So given $\varepsilon>0$ there exists $\delta>0$ such that $$\left|\frac{f(x)-f(tx)}{x} - b\right| < \varepsilon$$ whenever $|x|<\delta.$ Therefore $$|f(x) - f(tx) - bx| < \varepsilon|x|.$$ Next, if $|x|<\delta$ then $|t^nx|<\delta$ for all $n\geqslant1$ (because $t<1$). So in the above inequality we can replace $x$ by $tx$, $t^2x,\ldots, t^{n-1}x,$ to get $$|f(tx) - f(t^2x) - btx| < \varepsilon t|x|,$$ $$|f(t^2x) - f(t^3x) - bt^2x| < \varepsilon t^2|x|,$$ $$\ldots$$ $$|f(t^{n-1}x) - f(t^nx) - bt^{n-1}x| < \varepsilon t^{n-1}|x|.$$ Now add those inequalities and use the triangle inequality, to get $$\left|\sum_{k=0}^{n-1}\bigl(f(t^kx) - f(t^{k+1}x) - bt^kx\bigr)\right| \leqslant \sum_{k=0}^{n-1}\bigl|f(t^kx) - f(t^{k+1}x) - bt^kx\bigr| < \sum_{k=0}^{n-1} \varepsilon t^k|x|.$$ It follows, by summing the geometric and telescoping series, that $$\left| f(x) - f(t^nx) - \frac{b(1-t^n)x}{1-t} \right| < \frac{\varepsilon(1-t^n)|x|}{1-t}.$$ Now you can let $n\to\infty$ and use the facts that $t^nx\to0$ and $f$ is continuous at $0$, to deduce that $$\left| f(x) - f(0) - \frac{bx}{1-t}\right| \leqslant \frac{\varepsilon |x|}{1-t}.$$ After dividing through by $|x|$, you should be able to see that $f'(0)$ exists, and is equal to $\dfrac b{1-t}.$
I understand!Thank you very much! :D
  • · Replies 23 ·
  • · Replies 0 ·
  • · Replies 22 ·
  • · Replies 24 ·
