MHB Show that φ(v)=λv for a vector v and a coefficient λ
mathmari
MHB
Hey! 😊
Let $\mathbb{K}$ be a field, $1\leq n\in \mathbb{N}$ and let $V$ be a $\mathbb{K}$-vector space with $\dim_{\mathbb{R}}V=n$. Let $\phi :V\rightarrow V$ be a linear map.
The following two statements are equivalent:
- There is a basis $B$ of $V$ such that $M_B(\phi)$ is an upper triangular matrix.
- There are subspaces $U_1, \ldots , U_n\leq_{\mathbb{K}}V$ such that $U_i\subset U_{i+1}$ and $U_i$ is $\phi$-invariant.
Let $\phi$ satisfy the above properties. Then show that there is $0\neq v\in V$ and a $\lambda\in \mathbb{K}$ such that $\phi (v)=\lambda v$.
For that I have done the following:
We consider the subspace $U_1$. Since $U_1$ is $\phi$-invariant, it follows for $v\in U_1\subset V$ that $\phi (v)=\lambda v$, with $\lambda\in \mathbb{K}$.
Is that correct and complete? :unsure:
mathmari said:
Hey! 😊
The two statements that you have mentioned are equivalent provided you assume that $U_1$ is not the trivial subsspace and the containments $U_i\subseteq U_{i+1}$ are strict.
With this, you, in your argument, need to mention $U_1$ is necessarily one dimensional (do you see why) and that $v$ can be chosen to be nonzero.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
