Show that f'(x) grad f(x) is positive
In summary, the conversation is about proving a statement for a differentiable function, where the limit of a specific expression is shown to be greater than or equal to 0. The definitions of directional derivative and total differential are provided and used to solve the problem. There is a discussion about the meaning of total differentiability and how it allows for choosing any direction.
JulienB
408
Hi everybody! I'm preparing a maths exam so I run through a lot of problems, and I am unsure whether I tackled this one correctly or not:
Prove that for every differentiable function ##f: \mathbb{R}^3 \to \mathbb{R}## and for every point ##x \in \mathbb{R}^3## the following statement is true:
##\lim\limits_{t \to 0} \frac{f(x+t \nabla f(x)) - f(x)}{t} \geq 0##
I have the following definitions:
##f'(x) = \frac{\partial (f_1, ..., f_m)}{\partial (x_1, ..., x_n)} (x)##
Directional derivative: ##f'(x)v = \lim\limits_{t \to 0} \frac{1}{t} (f(x + tv) - f(x))##
So what I did was pretty straightforward:
##\lim\limits_{t \to 0} \frac{f(x + t \nabla f(x)) - f(x)}{t} = f'(x) \nabla f(x)##
##= [\partial_1 f(x) \partial_2 f(x) \partial_3 f(x)] \cdot [\partial_1 f(x), \partial_2 f(x), \partial_3 f(x)]##
##= (\partial_1 f(x))^2 + (\partial_2 f(x))^2 + (\partial_3 f(x))^2 \geq 0##
Is that legit? Not sure about my handling from ##f'(x)##. Should I have used the total differential definition? Would I obtain the same result? I'm still unclear about total derivatives :)Thanks a lot in advance for your answers.Julien.
Julien.
For a vector ##\vec{u} \in R^3## we have
$$\lim_{t \to 0} \frac{f(\vec{x} + t \vec{u}) - f(\vec{x})}{t} = \langle \vec{u}, \vec{\nabla} f(\vec{x}) \rangle,$$
where ##\langle \vec{p}, \vec{q} \rangle## denotes the inner product of the vectors ##\vec{p}, \vec{q}##. You are taking ##\vec{u} = \vec{\nabla} f(\vec{x})##.
Likes JulienB
It looks right to me. I would have written the limit as ##(\nabla_{(\nabla f)(x)}f)(x) \overset{(*)}= (\nabla f (x))\cdot (\nabla f (x)) = |\nabla f (x)|^2##. The total differentiability of ##f## is hidden in ##(*)## which allows you to write the directional derivative in direction ##v## (##=(\nabla f)(x)## in this case) as ##D_v f(x) = \nabla f(x) \cdot v##. Other than directional differentiability and partial differentiability (which are simply special directional derivatives), the total differentiability allows us to choose any direction. In this case ##v=(\nabla f)(x)## is a linear combination of partial derivatives.
Likes JulienB
@Ray Vickson Hi and thanks for your answer! I like the way you write the definition with the inner product. At the end it gives the same result that I wrote, right?
@fresh_42 Hello and thank you for your answer as well. :) Of course I realized the equality holds only because the problem states that the function is differentiable. I am still unsure about the meaning of the total derivative. So far I understand it like that: the partial differentials hold for analytical use of a function, while the total differential becomes useful when wanting to approximate the slope at a given point. Would you support that statement? If not, could you maybe give me an example of partial and total differentiation so that I can visualise it? My interpretation is based on the following observation (for the case ##f: \mathbb{R}^n \to \mathbb{R}##):
##f' (\vec{x}) = \frac{\partial (f_1, ... , f_m)}{\partial (x_1, ... , x_n)} (x) = \mbox{vector}##
##f' (\vec{x}) = \sum \frac{\partial f}{\partial x_i} dx_i = \mbox{scalar}##
First of all, is that correct? And if so, would you say that "the total differentiability allows us to choose any direction" when we plug in arbitrary ##dx_i## for a given point ##\vec{x}##?Thanks a lot again to both of you for your answers, I really appreciate your explanations!Julien.
Not really. Partial derivatives also approximate the slope at a given point. Just in the direction of the coordinates. A total differential approximates a function ##f## as a whole by a linear function ##L## (the total differential), i.e. you may write ##f(\vec{x}+\vec{v}) = f(\vec{x}) + L(\vec{v}) +r(\vec{v})## such that ##\lim_{\vec{v} \rightarrow 0} \frac{r(\vec{v}}{||\vec{v}||} = 0##. This means ##f## can be approximated by ##L## such that the error terms in ##r## run faster towards zero than ##L## does, or as it often occurs (e.g. in Taylor expansions), ##r## has terms in ##\vec{v}## of higher orders than ##1##.
I have difficulties with naming everything ##x##. You should try to get used to distinguish when you are speaking of a function in the variable ##x##, coordinates ##x_i## or ##x^i## and eventual evaluation points ##x_0=p,## e.g. where the derivative is evaluated at. I'm not sure if I got you right. E.g. you may denote a gradient better by $$grad(f) = \nabla f = \sum_{i=1}^{n}\frac{\partial f}{\partial x_i} \vec{e}_i$$ or more physical $$\nabla f = \sum_{i=1}^{n}\frac{\partial f}{\partial x_i} dx_i$$ and $$\nabla_p f = \sum_{i=1}^{n}\left(\frac{\partial f}{\partial x_i}\right)_{x=p} dx_i$$
In addition, how can ##f'(\vec{x})## simultaneously be a vector and a scalar? Only by evaluation of ##\nabla_p f## at a certain point, which should not be denoted by the variable name.
An example for the difference between partial and total differentiation is the following:
$$f(\vec{x}) = \begin{cases} \frac{2x_1x_2}{x_1^2+x_2^2} & \text{if } (x_1,x_2) \neq (0,0) \\ \\ 0 & \text{if } (x_1,x_2) = (0,0) \end{cases}$$
##f## is partially differentiable at ##(0,0)## but not continuous at ##(0,0)##. And you might want to calculate what happens along the line ##x_1 = x_2##. The latter is an example of a direction that is not along a coordinate.
Likes JulienB
@fresh_42 Thank you again for your answer, it is very complete and I am slowly starting to understand. I will study the matter for some more time on my own and probably come back here for more questions later on :)
Julien.
Related to Show that f'(x) grad f(x) is positive
1. What does "Show that f'(x) grad f(x) is positive" mean?
This statement is asking you to prove that the product of the derivative of a function f and the gradient of f is always positive.
2. Why is it important to show that f'(x) grad f(x) is positive?
This is important because it tells us that the function f is increasing in the direction of the gradient, meaning that its output is getting larger as we move in that direction. It also helps us understand the behavior of the function and make predictions about its values.
3. How do you prove that f'(x) grad f(x) is positive?
To prove that this statement is true, you can use the definition of the gradient and the derivative, as well as properties of multiplication. You will need to show that the resulting expression is always greater than zero for any value of x.
4. What are some real-life applications of f'(x) grad f(x) being positive?
This concept is commonly used in fields such as physics, engineering, and economics to analyze and optimize systems. For example, it can be used to understand how a stock's value changes over time, or how a rocket's trajectory is affected by different variables.
5. Are there any exceptions to f'(x) grad f(x) being positive?
Yes, there can be exceptions to this rule. For example, if the function f is constant or decreasing in the direction of the gradient, then the product of the derivative and the gradient will be negative. Additionally, this statement may not hold true for multidimensional functions with more than one gradient direction.
