Show that ##\frac{1}{x^2}## is not uniformly continuous on (0,∞).
In summary, we want to show that ##f(x)=\frac{1}{x^2}## is not uniformly continuous at ##(0,\infty)## by finding specific values of ##x## and ##y## that satisfy the conditions ##\vert x-y\vert\lt\delta## and ##\vert f(x)-f(y)\vert\gt 1##. This can be done by taking the limit as ##y\to 0##, which shows that ##\vert f(x)-f(y)\vert## tends to infinity, proving that ##f## is not uniformly continuous.
Terrell
317
Show that ##f(x)=\frac{1}{x^2}## is not uniformly continuous at ##(0,\infty)##.
N/A
Given ##\epsilon=1##. We want to show that we can compute for ##x## and ##y## such that ##\vert x-y\vert\lt\delta## and at the same time ##\vert f(x)-f(y)\vert\gt 1##. Note that
\begin{align}
\vert x-y\vert\lt\delta &\Leftrightarrow y-\delta\lt x \lt y+\delta
\end{align}
So let ##x=y+\delta/2##. Now to link the desired conditions on ##x## and ##y##, we compute for ##\vert \frac{1}{x^2}-\frac{1}{y^2}\vert \gt 1 \Leftrightarrow \vert \frac{1}{(y+\frac{\delta}{2})^2}-\frac{1}{y^2}\vert \gt 1 \Leftrightarrow \vert \frac{y\delta+\frac{\delta^2}{4}}{y^4+y^3\delta+(\frac{\delta}{2})^2}\vert \gt 1##.
Since ##\lim_{y\to 0}(\frac{y\delta+\frac{\delta^2}{4}}{y^4+y^3\delta+(\frac{\delta}{2})^2})=\infty##, since ##\delta## is fixed, then we can find ##x## and ##y## such that ##\vert f(x)-f(y)\vert \gt 1##.
Likes FactChecker and Delta2
1) The denominator should be ##y^4+y^3\delta+y^2(\frac{\delta}{2})^2## ok this is just a typo I guess...
2) ##\delta## is not exactly fixed, as we want to compute specific ##x(\delta),y(\delta)## for any ##\delta## but yes that limit is ##+\infty## for any ##\delta>0##...
Likes Terrell and FactChecker
Alternatively, take ##a_n:= \frac{1}{n}, b_n := \frac{1}{n+1}##. Then ##a_n - b_n \to 0## but it is not true that ##f_(a_n)-f(b_n) = n^2 - (n+1)^2 \to 0##. Hence, ##f## can't be uniformly continuous.
Likes Terrell
slick! Thank you!
Related to Show that ##\frac{1}{x^2}## is not uniformly continuous on (0,∞).
1. Why is it important to show that 1/x^2 is not uniformly continuous on (0,∞)?
It is important because uniform continuity is a property that describes the behavior of a function at all points within a given interval. If a function is not uniformly continuous, it means that it does not have a consistent rate of change throughout the interval, which can have implications for its overall behavior and usefulness in mathematical models.
2. How can you prove that 1/x^2 is not uniformly continuous on (0,∞)?
To prove that a function is not uniformly continuous on a given interval, we can use the epsilon-delta definition of uniform continuity. This involves using a specific value of epsilon (ε) to find a corresponding value of delta (δ) such that for all x and y within the interval, if |x-y| < δ, then |f(x)-f(y)| > ε. For 1/x^2, we can choose a specific value of ε and show that no matter what value of δ we choose, there will always be x and y within the interval for which the inequality is not satisfied.
3. What is the difference between uniform continuity and regular continuity?
Uniform continuity is a stronger condition than regular continuity. While regular continuity only requires that a function is continuous at each point within a given interval, uniform continuity requires that the rate of change of the function is consistent throughout the entire interval. In other words, a function can be continuous but not uniformly continuous, but a function cannot be uniformly continuous without also being continuous.
4. Can 1/x^2 be uniformly continuous on any other interval besides (0,∞)?
Yes, it is possible for 1/x^2 to be uniformly continuous on other intervals. For example, it is uniformly continuous on (1,∞), since it is a subset of (0,∞) and the function is bounded and continuous on this interval. However, it is not uniformly continuous on (0,1), as the function is unbounded and discontinuous at x=0.
5. How does the graph of 1/x^2 illustrate its lack of uniform continuity on (0,∞)?
The graph of 1/x^2 shows that as x approaches 0, the slope of the function becomes increasingly steep. This means that for any chosen value of ε, we can always find points x and y within the interval for which the difference in the function values exceeds ε, no matter how small we make the interval around x=0. This illustrates the lack of uniform continuity, as the rate of change of the function is not consistent throughout the interval.
