Show that gcd(a,b) is the smallest positive element in the set {ma+nb}
The discussion centers on proving that the greatest common divisor (gcd) of two integers a and b is the smallest positive element in the set {ma + nb | m, n ∈ ℤ}. It establishes that if a and b are relatively prime, integers m and n can be found such that ma + nb = 1, making 1 the smallest positive element. In cases where a and b are not relatively prime, a common divisor c exists, leading to the conclusion that gcd(a, b) = c. The proof hinges on the properties of integers and the closure of the set under addition and multiplication. Overall, the gcd is shown to be the smallest positive element in the defined set.
docnet
let ##a,b\in\mathbb{N}##. Show that ##gcd(a,b)## is the smallest positive element in the set ##\{ma+nb|m,n\in\mathbb{Z}\}##.
(1) If ##a## and ##b## are relatively prime, then tere are integers ##m## and ##n## such that ##ma+nb=1##
(2) If ##a>b## then ##gcd(a-b,b)=gcd(a,b)##
##m##, ##n##, ##a##, and ##b## are in ##\mathbb{Z}##. The set of natural numbers is an abelian group, so ##\{ma+nb|m,n\in\mathbb{Z}\}## is a subset of ##\mathbb{Z}##.
##a ## and ##b## are either relatively prime or not relatively prime.
If ##a ## and ##b## are relatively prime, then there are integers ##m## and ##n## such that ##ma+nb=1##. ##1## is the smallest positive element in ##\mathbb{Z}##. So, ##1## is the positive smallest positive element in ##\{ma+nb|m,n\in\mathbb{Z}\}##.
If ##a ## and ##b## are not relatively prime, then there is an integer ##c## that commonly divides ##a## and ##b##. So ##a=\tilde{a}c## and ##b=\tilde{b}c##, where ##\tilde{a}## and ##\tilde{b}## are relatively prime integers.
\begin{align}ma+nb=&m\tilde{a}c+n\tilde{b}c\\
=&c(m\tilde{a}+n\tilde{b})\end{align}
##\tilde{a}## and ##\tilde{b}## are relatively prime, so there exist integers ##m## and ##n## such that ##m\tilde{a}+n\tilde{b}=1##, And because they are relatively prime, ##gcd(\tilde{a},\tilde{b})=1##,
\begin{align}=& c\cdot gcd(\tilde{a},\tilde{b})=gcd(a,b)=c\end{align}
##1## is the smallest positive element in ##\{m\tilde{a}+n\tilde{b}|m,n\in\mathbb{Z}\}## so
##c\cdot 1 =gcd(a,b)## is the smallest positive element in ##c\cdot \{m\tilde{a}+n\tilde{b}|m,n\in\mathbb{Z}\}=\{ma+nb|m,n\in\mathbb{Z}\}##.
docnet said:
Homework Statement:: let ##a,b\in\mathbb{N}##. Show that ##gcd(a,b)## is the smallest positive element in the set ##\{ma+nb|m,n\in\mathbb{Z}\}##.
Relevant Equations:: (1) If ##a## and ##b## are relatively prime, then tere are integers ##m## and ##n## such that ##ma+nb=1##
Under what addition?
docnet said:
If a and b are not relatively prime, then there is an integer c that commonly divides a and b.
Later the proof says ##c = \gcd(a, b)##.
What are ##m, n## in line (1)?
docnet said:
so there exist integers m and n such that ma~+nb~=1,
are these the same ##m, n## as before?Hint: Let ##ma + nb## be an arbitrary positive element in ##\lbrace xa + yb \vert x, y \in \mathbb{Z} \rbrace## and define ##d = \gcd(a, b)##. Then ##d \vert ma + nb##. (why?).
Oh no. The correct statement was "The set ##\mathbb{Z}## is closed under multiplication and addition, so the element ##ma+nb## for any ##a,b,n,m\in\mathbb{Z}## is also in ##\mathbb{Z}##.
I am confused. Is this not true when ##a## and ##b## are not co-prime?
No. They are different integers than before.
Okay, I will try to come up with the correct solution using this hint. Thank you.
