Show that if U and T are onto, then UT is also onto
  • Thread starter Mr Davis 97
In summary, the conversation discusses how to show that the composition of two onto functions, U and T, is also onto. It is shown that for any element z in the codomain Z, there exists a corresponding element v in the domain V such that U(T(v)) = z, by first using the surjectivity of U to find a w in the codomain W that maps to z, and then using the surjectivity of T to find a v in the domain V that maps to w. This shows that UT is also onto.
Mr Davis 97
1,462
44
Same as title, where T maps from a set V to W, and U maps from W to Z.
I know that the standard definition for a function being onto is that for all elements w in the codomain, there exists an element v in the domain such that T(v) = w. I am not sure exactly how to concretely apply this to show that U composed with T is also onto.
To start, we have U(T(v)) = z, and we need to show that for all z in Z there exists a v in V such that that mapping is true. First we can use the fact that U is onto, which means there is always a w = T(v) that maps to z, and since T is onto, there is always a v that maps to w. Is this sufficient to show that UT is also onto? Is there a way to write this argument using less words?
You confused the order a bit.
To start let's see what we have (which is always a good idea): ##\;V \stackrel{T}{\twoheadrightarrow} W \stackrel{U}{\twoheadrightarrow} Z##.
A map ##f: X \twoheadrightarrow Y## is surjective, if the following is true (you have already said this, but you asked for a short way to write it):
$$ \forall \; y \in Y \, : \, f^{-1}(y) = \{x \in X\,\vert \,f(x)=y\} \neq \emptyset \stackrel{or}{\Longleftrightarrow} \forall \; y \in Y \; \exists \; x\in X \, : \, f(x)=y$$
Now we have to start with an arbitrary point ##z \in Z##. The ##v\in V## for which ##U(T(v))=z## holds, has to be shown to exist.
So first, you have to get back from ##Z## to ##W## by ##U\; -\;## no ##v##, no ##V## and no ##T## at this stage, because all you have is an arbitrary element ##z \in Z## for which you need to show ##(U \circ T)^{-1}(z) \neq \emptyset \; .##
If you have your element in ##W##, then you can proceed using ##T##, but not earlier.
But U is surjective, so there must be a w in W s.t. U(w) = z, for any z in Z
Yes, and for those ##w## you can repeat the argument now with ##T##.
So, basically, we need to show that for all z in Z there exists a v in V s.t. UT(v) = U(T(v)) = z, and we do this by first noting that there must be a w in W s.t. U(w) = z, and also that there must be a v in V s.t. T(v) = w, and hence there must be a v in V s.t. UT(v) = z? For my purposes is this an okay way of putting the argument?
Yes. I would drop the word surjective in both cases to justify the existence of those elements, but yes, that's it.
Likes Mr Davis 97
Related to Show that if U and T are onto, then UT is also onto
1. How do you prove that if U and T are onto, then UT is also onto?
To prove this statement, we must show that for every element in the range of UT, there exists an element in the domain of UT that maps to it. In other words, for every y in the range of UT, there exists an x in the domain of UT such that UT(x) = y. This can be done using a direct proof or a proof by contradiction.
2. Can you provide an example to illustrate this statement?
Yes, consider the functions U: {1, 2, 3} -> {a, b, c} and T: {a, b, c} -> {x, y, z}. Both U and T are onto because every element in their respective ranges is mapped to. Now, let's look at UT: {1, 2, 3} -> {x, y, z}. We can see that for every element in the range of UT, there exists an element in the domain of UT that maps to it. For example, y in the range of UT is mapped to by b in the domain of UT, as UT(2) = y. Therefore, UT is also onto.
3. What is the significance of proving that UT is onto?
Proving that UT is onto is important because it shows that the composition of two onto functions will always result in an onto function. This means that the range of the composite function will be equal to the codomain, and every element in the codomain will have at least one element in the domain that maps to it. This is a useful property in many areas of mathematics and science.
4. Is it possible for UT to be onto if either U or T is not onto?
No, if either U or T is not onto, then UT cannot be onto. This is because if an element in the range of UT does not have a corresponding element in the domain of UT, then UT cannot be onto. For example, if T is not onto and there exists an element in the range of T that does not have a corresponding element in the domain of T, then there will also be an element in the range of UT that does not have a corresponding element in the domain of UT.
5. Can you use a proof by contrapositive to prove this statement?
Yes, a proof by contrapositive can also be used to prove this statement. The contrapositive of this statement is "if UT is not onto, then either U or T is not onto." To prove this, we assume that UT is not onto and show that either U or T is not onto. This can be done by assuming that U and T are both onto and reaching a contradiction, thus proving the contrapositive and the original statement.
