Show that is the square of an integer
In summary, the conversation discusses a problem about positive integers and their divisibility, specifically related to the expression $\frac{a^2 + b^2}{ab + 1}$ and its square being an integer. The conversation includes a solution and some doubts about its generality. The participants also mention that this problem was a question in the 1988 International Mathematical Olympiad.
Joppy
MHB
284
I couldn't find this problem anywhere else on the forum so I thought I'd post it. If however, I am duplicating, mods feel free to remove the post :p.
No doubt many of you know it already, but I found it quite interesting.
Let $a$ and $b$ be positive integers such that $ab + 1$ divides $a^2 + b^2$. Show that $\frac{a^2 + b^2}{ab + 1}$ is the square of an integer.
Mathematics news on Phys.org
Let $a$ and $b$ be positive integers such that $ab + 1$ divides $a^2 + b^2$. Show that $\frac{a^2 + b^2}{ab + 1}$ is the square or an integer.
This one's infuriating. I love it!
-Dan
-Dan
So many layers!
my solution:
if $a=b^3$
then $\dfrac {a^2+b^2}{ab+1}=\dfrac {b^6+b^2}{b^4+1}=b^2$
if $b=a^3$
then $\dfrac {a^2+b^2}{ab+1}=\dfrac {a^2+a^6}{a^4+1}=a^2$
$\therefore ab+1$ divides $a^2+b^2$ we may set $a=b^3,or\,\, b=a^3$
(here $a,b \in N$)
This is problem #3 day 2 of the 1988 IMO.
Thought it was no. 6.
Albert said:
my solution:
if $a=b^3$
if $b=a^3$
(here $a,b \in N$)
How do we know that this is the most general solution (or that others don't exist)? I can't think of how to prove that one way or another.
-Dan
-Dan
I think Albert has stumbled upon one set of solutions, but there are many more in similar forms.. But! I'll have to check myself first when I get a chance.
-Dan
since we are given :$a^2+b^2 $ is a multiple of $ab+1$
we must find the relation between $a$ and $b$ as my example $a=b^3$ or $b=a^3$
may be we can find different link between $a,b$ and check the result
the following steps will help us finding other solutions:
if $a>b$
take $\dfrac {a^2+b^2}{ab+1}=2^2=4=k^2----(*)$ for instance
(1) set $a=b^3$,we get $a=8,b=2$
(2) put $b=8 $ to $(*)$ we get $a=2$ ,or $a=30$ another solution $ (a,b)=(30,8) $ is found
(3) put $b=30$ to $(*)$ we get $a=8$ or $a=112$ again $(a,b)=(112,30)$ is found
(4) put $b=112 $ to $(*)$ we get $a=30$ ,or $a=418$ another solution $ (a,b)=(418,112) $ is found
continue these steps until no other solution found then next $k$
if $a>b$
The general solutions of :$\dfrac {a^2+b^2}{ab+1}=k^2-----(*)\,\,\,(a,b,k\in N)$
because of symmetry we let $a>b$
from previous solution we have $ b=k,a=b^3=k^3 $
put $b=k^3$ to $(*)$
we find another solution of $a$
$\dfrac {a^2+k^6}{ak^3+1}=k^2$
$\rightarrow a^2-ak^5+k^6-k^2=0$
$a=k,\,\, or \,\ ,a=k^5 - k$
Albert,
you are digressing
you are finding general solution instead of proving that it is perfect square
kaliprasad said:
Albert,
you are digressing
may be a little bit digressing,but from this I can deduce that it is perfect square:
$let :\dfrac{a^2+b^2}{ab+1}=y\\
a^2-yab+b^2-y=0\\
a=\dfrac{yb\pm\sqrt{y^2b^2-4b^2+4y}}{2}$
since $a,b\in N$
$y^2b^2-4b^2+4y$ must be perfect square
this can only be done with $b=y\sqrt y=k^3$
$a=\dfrac {y^2\sqrt y \pm (y^2\sqrt y-2\sqrt y)}{2}=y^2\sqrt y-\sqrt y =k^5-k\,\, or \,\, a=\sqrt y=k$
as given from general solution
here $(y=k^2)$ must be perfect square
a^2-yab+b^2-y=0\\
since $a,b\in N$
This is a mixup between arithmetic and algebra. for example $b^2+5$ is not a perfect square in algebra but is it in arthmetic when $b=2$ as $2^2+5= 3^2$
note $a,b\in N$ and $ab+1$ divides $a^2+b^2$
$y^2b^2-4b^2+4y=(yb-2\sqrt y)^2$ is perfect square
this implies $b=y\sqrt y \in N$
$\therefore y$ must be perfect square
so $y=k^2, b=k^3$
FAQ: Show that is the square of an integer
What does it mean for a number to be a "square of an integer"?
When a number is the square of an integer, it means that the number can be written as the product of two equal integers. For example, 9 is the square of 3 because 9 can be written as 3 x 3.
How can I show that a number is the square of an integer?
To show that a number is the square of an integer, you can take the square root of the number and check if the result is a whole number. If the result is a whole number, then the original number is the square of that whole number. For example, the square root of 16 is 4, so 16 is the square of 4.
Can any number be the square of an integer?
No, not every number can be the square of an integer. A number must have a whole number square root in order to be the square of an integer. For example, 2 is not the square of an integer because its square root is √2, which is not a whole number.
Is the square of an integer always a positive number?
Yes, the square of an integer is always a positive number. This is because when you multiply two positive numbers, the result is always positive. So, when a number is the square of an integer, it is always positive.
Can a negative number be the square of an integer?
Yes, a negative number can be the square of an integer. For example, -4 is the square of -2 because (-2) x (-2) = 4. However, the square of an integer is always a positive number, so when we say "the square of an integer" we typically mean the positive square of an integer.
