Show that limit set of dynamical system is closed
In summary, the w-limit set (omega) of a point is defined as the set of points to which there exists a sequence t_n→∞ such that \phi(t_n,x) → y. To show that w(x) is closed, it suffices to show that if y is a limit of ω-limit points, then y is also an ω-limit point. This can be done by constructing a sequence t_n such that |phi(t_n,x) - y| < 1/n, which shows that y is in w(x) and therefore in its closure.
saxen
44
Define the w-limit set (omega) of a point. Show that w(x) is closed.
The definition of a limit set is the set of points to which there exists a sequence t_n→∞ such that [itex]\phi(t_n,x)[/itex] → y
The second question. I was first thinking that I could try to find a sequence to show that y is in the closure of w(x) but my real analysis/topology skills are bad and I could really use some help!
All help is greatly appreciated!
You want to show that if ##y## is a limit of ω-limit points, i.e. there is a sequence of ω-limit points ##y_m## such that ##y_m \rightarrow y##, then ##y## is a ω-limit point. Your thinking about how to do it is exactly correct. Take it step by step. Can you show there is a ##t_1## such that [itex]|\phi(t_1,x)-y|<1[/itex]? Now can you show there is a ##t_2>t_1## such that [itex]|\phi(t_2,x)-y|<\frac{1}{2}[/itex]? Etc, etc. It's not hard. Use the definitions and the triangle inequality.
this is almost a tautology. a closed set is one which contains its limit points. so if a set of limit points exist, that set will be closed automatically. they don't have to be the unique limit of a sequence, just that there is an indexed infinite set which comes arbitrarily close to it. (but maybe I'm approaching this backwards...)
You are oversimplifying. This is a special notion of limit points. The ω-limit points aren't even all limit points. They are only the 'future' limit points of the dynamical trajectory. It's really best (and not even hard) to take this from first principles.
if i understand you, you're looking at showing the intersection set of all the tails of a given trajectory is closed?
I'm just saying approach it directly. Don't use any abstract properties of limit points. Construct a sequence of ##t_n## that show ##y## is an ω-limit point.
I forgot about this thread. I had some problem with the last part of this question but found a proof that helped me:
phi denotes the flow.
Let y be in the closure of w(x). Then there exists a sequence y_n in w(x) such that |y-y_n| < 1/2n. Moreover chosoe a sequence s.t t_n --> inf |phi (t_n,x)-y_n| <1/2n. Then |phi (t_n,x)-y| < 1/n and y is in w(x).
edit: sorry for format, TeX is not working for me.
FAQ: Show that limit set of dynamical system is closed
What is a dynamical system?
A dynamical system is a mathematical model that describes the time-evolution of a system over a period of time. It consists of a set of equations that determine how the state of the system changes over time.
What is a limit set of a dynamical system?
The limit set of a dynamical system is the set of all possible values that the system can reach as time approaches infinity. It represents the long-term behavior of the system.
How is the limit set of a dynamical system related to chaos?
The limit set of a chaotic dynamical system is often a fractal, meaning that it has a self-similar structure at different scales. This is a characteristic of chaotic systems, where small changes in initial conditions can lead to drastically different long-term behavior.
Why is it important to show that the limit set of a dynamical system is closed?
Showing that the limit set of a dynamical system is closed is important because it guarantees the existence of a stable equilibrium point, where the system will eventually converge to and remain at for all future time. This is a crucial property for understanding and predicting the behavior of a dynamical system.
How can the limit set of a dynamical system be proven to be closed?
The limit set of a dynamical system can be proven to be closed by showing that any sequence of states within the system will converge to a point within the set. This can be done using various mathematical techniques, such as Lyapunov stability analysis or the Poincaré-Bendixson theorem.
