Show that potential energy is conserved
In summary: You get##\frac12 \dot x^2=E-U(x)##Where E is a constant of integration. This is the equation for a particle with unit mass and energy E in a potential U(x).In summary, the conversation discussed the potential energy function of U(x) = 4x^2 + 3 and the task of finding the equation of motion and proving the conservation of total energy. The conversation explored different equations and methods, such as differentiating the potential energy function to find the force, using the equation F = -dU/dx, and integrating to find the equations of motion for a 1D case. The conversation also considered the energy expression, the role of kinetic energy, and the
gelfand
40
potential energy function of :
U(x) = 4x^2 + 3
And have to
i) Work out the equation of motion
ii) Prove explicitly that the total energy is conserved
F = \frac{dU}{dt}
I'm not too sure how to go about this.
I would say that I have the force of
F = 8x
By differentiating the given potential energy function. I need to work out the
equation of motion, what I have an object with mass ##m##.
So this means that I have
F = 8x = ma
Then I have that
a = \frac{8x}{m}
Is this an equation of motion? I mean, it's acceleration, or should I find for
##v(t)## and ##x(t)## as well as this?
In which case I would have
v(t) = \int a(t) dt
Which in this case is found as (having the mass in the equation seems unusual?)
v(t) = v_0 + \frac{1}{2m}8x^2 = v_0 + \frac{4}{m} x^2
$$So then from this I have that
x(t) = x_0 + v_0t + \frac{4}{3m}x^3
And this would be all of the equations of motion for this 1D case?
Then I need to prove that energy is conserved here, and I've no idea how to go
about that.
I've not been given any frictional forces, so it seems like it's just a given
that I'm going to have
W + PE_0 + KE_0 =
PE_f + KE_f + \text{Energy(Lost)}
Here I can remove work ##W## and the energy lost for
PE_0 + KE_0 =
PE_f + KE_f
And I need to do something with these?
Potential energy - I have the potential energy function given as part of the
problem which is
U(x) =
4x^2 + 3
Then I can sub this into the energy expression as
4x_0^2 + 3
+ KE_0 =
4x_f^2 + 3
+ KE_f
Getting rid of the constants seems pretty harmless
4x_0^2
+ KE_0 =
4x_f^2
+ KE_f
Now I'm really not sure what I should do from here, sub in kinetic formulas of
##K = \frac{1}{2}mv^2##?
4x_0^2
\frac{1}{2}mv_0^2
4x_f^2
\frac{1}{2}mv_f^2
I'm not sure if I can arrange this to be 'nicer' in any way either, I'm purely
thinking in algebra at the moment though not physics :S$$
8(x_0^2 - x_f^2) =
m(v_f^2 - v_0^2)
I'm not sure if differentiation should do anything nice here, but I really have
no idea what I'm doing with this.
Thanks
gelfand said:
2. Homework Equations ##F = \frac{dU}{dt}##
Dividing energy by time gives power, not force.
OK ##F = - \frac{dU}{dx}## sorry , I'm still unsure about the question
You got a=8x/m ok, but you cannot integrate that wrt t directly. The expression you got for v(t) was the integral wrt x (which just gets you back to U).
There is a useful trick for solving equations like ##\ddot x=f(x)##. Multiply both sides by ##\dot x##, then integrate dt.
Related to Show that potential energy is conserved
1. What is potential energy?
Potential energy is a type of energy that an object possesses due to its position or state. It is stored energy that has the potential to do work in the future.
2. How is potential energy conserved?
The law of conservation of energy states that energy cannot be created or destroyed, only transferred or converted from one form to another. This means that potential energy can be converted into other forms of energy, but the total amount of energy in a closed system remains constant.
3. What are some examples of potential energy?
Some examples of potential energy include gravitational potential energy (an object's potential to fall), chemical potential energy (stored in chemical bonds), and elastic potential energy (stored in stretched or compressed materials).
4. Can potential energy be negative?
Yes, potential energy can be negative. This usually occurs when the reference point for measuring potential energy is set at a higher point than the actual position of the object. For example, if an object is lifted above a reference point, it will have positive potential energy. But if it is below the reference point, it will have negative potential energy.
5. How is potential energy conservation applicable in real life?
Potential energy conservation is applicable in many real-life scenarios, such as in roller coasters, pendulums, and water dams. In all of these cases, potential energy is converted into other forms of energy, such as kinetic energy or electricity, to perform work. Understanding the conservation of potential energy is also important in fields like engineering and physics, where it is used to analyze and design various systems and structures.
