Show that ##pV^\gamma## is a constant for an adiabatic process
In summary: The ideal gas law is used in the derivation of ##PV^\gamma=##constant, so it is assumed that the gas is ideal.
alexmahone
304
Assume that gases behave according to a law given by ##pV = f(T)##, where ##f(T)## is a function of temperature. I have derived the following results:
##\displaystyle\left(\frac{\partial p}{\partial T}\right)_V=\frac{1}{V}\frac{\partial f}{\partial T}## ----------------------- (1)
##\displaystyle\left(\frac{\partial V}{\partial T}\right)_p=\frac{1}{p}\frac{\partial f}{\partial T}## ----------------------- (2)
##\displaystyle\left(\frac{\partial Q}{\partial V}\right)_p=C_p\left(\frac{\partial T}{\partial V}\right)_p## ----------------------- (3)
##\displaystyle\left(\frac{\partial Q}{\partial p}\right)_V=C_V\left(\frac{\partial T}{\partial p}\right)_V## ----------------------- (4)
Now,
## \displaystyle dQ=\left(\frac{\partial Q}{\partial p}\right)_V dp+\left(\frac{\partial Q}{\partial V}\right)_p dV##
In an adiabatic change, ##dQ=0##.
So, ## \displaystyle\left(\frac{\partial Q}{\partial p}\right)_V dp+\left(\frac{\partial Q}{\partial V}\right)_p dV=0##
Using (3) and (4),
##\displaystyle C_V\left(\frac{\partial T}{\partial p}\right)_V dp+C_p\left(\frac{\partial T}{\partial V}\right)_p dV=0##
Dividing this equation by ##C_V##, we get
##\displaystyle\left(\frac{\partial T}{\partial p}\right)_V dp+\gamma \left(\frac{\partial T}{\partial V}\right)_p dV=0##
How do I proceed?
Note: I know there may be lots of ways (some easier than this) of showing that ##pV^\gamma## is a constant for an adiabatic process. But this is the method required by my textbook.
If [itex]pV = f(T)[/itex] then, differentiating with respect to [itex]p[/itex] with [itex]V[/itex] held constant, [tex]
V = f'(T) \left(\frac{\partial T}{\partial p}\right)_V[/tex] and vice-versa [tex]
p = f'(T) \left(\frac{\partial T}{\partial V}\right)_p.[/tex]
Likes alexmahone
Thanks!
Substituting these 2 results into ##\displaystyle\left(\frac{\partial T}{\partial p}\right)_Vdp+\gamma\left(\frac{\partial T}{\partial V}\right)_p dV=0##, we get
##\displaystyle\frac{V}{f'(T)}dp+\gamma\frac{p}{f'(T)}dV=0##
##\implies Vdp+\gamma pdV=0##
Dividing both sides by ##pV##,
##\displaystyle\frac{dp}{p}+\gamma\frac{dV}{V}=0##
Integrating, we get
##\ln p+\gamma\ln V=##constant
##\implies\ln p+\ln V^\gamma=##constant
##\implies\ln pV^\gamma=##constant
##\implies pV^\gamma=##constant
QED
One question though: Where have we used the fact that the gas is an ideal gas? Or does ##PV^\gamma=##constant hold for adiabatic processes of non-ideal gases as well?
An ideal gas is a special case of [itex]pV = f(T)[/itex] where [itex]f(T) = nRT[/itex].
Likes alexmahone
alexmahone said:
Thanks!
Integrating, we get
QED
It doesn't hold for non-ideal gases.
Likes alexmahone
FAQ: Show that ##pV^\gamma## is a constant for an adiabatic process
What is an adiabatic process?
An adiabatic process is a thermodynamic process in which there is no transfer of heat or matter between a system and its surroundings. This means that the system is thermally isolated and does not exchange energy with its surroundings.
How is ##pV^\gamma## related to an adiabatic process?
##pV^\gamma## is a mathematical expression that represents the relationship between pressure and volume in an adiabatic process. It is derived from the ideal gas law and is a constant for a given system undergoing an adiabatic process.
What does ##\gamma## represent in the equation ##pV^\gamma##?
##\gamma## is the adiabatic index or heat capacity ratio, which is a measure of how much a gas's internal energy changes with temperature. It is a constant for a specific gas and is dependent on the number of degrees of freedom of the gas molecules.
Why is ##pV^\gamma## constant in an adiabatic process?
In an adiabatic process, there is no transfer of heat, so the internal energy of the gas remains constant. This means that any change in pressure or volume must be balanced by an equal and opposite change to maintain the constant internal energy. This results in ##pV^\gamma## remaining constant throughout the process.
How is the constant ##pV^\gamma## useful in thermodynamics?
The constant ##pV^\gamma## is useful in thermodynamics because it allows us to calculate the work done by a gas in an adiabatic process without needing to know the exact details of the process. It also helps in understanding the behavior of gases under adiabatic conditions and can be used to determine the final state of a gas after an adiabatic process.
