Show that r is repeated root for characteristic equation iff
In summary, the conversation discusses the relationship between the kernel of a linear operator A - rI and its power (A - rI)^2, where r is a multiple root for the minimal polynomial u(x). It is stated that the kernel of (A - rI)^2 contains the eigenvectors associated with r, but not the kernel of (A - rI). The concept of a generalized eigenvector is introduced and it is suggested to use the fact that (x-r)^2 divides the minimal polynomial to find a vector v2 that satisfies (A - rI)v2 = v.
catsarebad
72
A:B→B a linear operator
Show r is multiple root for minimal polynomial u(x) iff
>$$\{0\}\subset \ker(A - rI) \subset \ker(A - rI)^2$$
note: it is proper subset
My thought:
I know ker(A−rI) is basically {{0} and {eigenvectors associated with r}}.
what is ker((A−rI)^2) with respect to above and/or r? How is eigenvector of (A−rI)^2 related to that of (L−rI)?
Have you ever heard of a generalized eigenvector?
http://en.wikipedia.org/wiki/Generalized_eigenvector
Suppose v is an eigenvector corresponding corresponding to r. If you could find a vector v2 such that (A - rI) v2 = v. Then:
(A - rI)2 v2 = (A - rI) v = 0​
So v2 [itex]\in[/itex] ker( (A - rI)2). But v2 [itex]\notin[/itex] ker(A - rI).
See if you can use the fact that (x-r)2 divides the minimal polynomial to show that such a v2 exists.
FAQ: Show that r is repeated root for characteristic equation iff
1. What is a repeated root in a characteristic equation?
A repeated root in a characteristic equation refers to a situation where one of the roots of the equation is repeated multiple times. This means that the equation has a root with a multiplicity greater than one.
2. How can you show that r is a repeated root for a characteristic equation?
In order to show that r is a repeated root for a characteristic equation, you can use the factor theorem. This theorem states that if a polynomial function has a root at r, then (x-r) is a factor of the polynomial. Therefore, if (x-r) is a factor of the characteristic equation, then r is a root with multiplicity greater than one.
3. What does it mean for a root to have a multiplicity greater than one?
Having a root with a multiplicity greater than one means that the root appears multiple times in the equation. For example, if the root is 3 and it has a multiplicity of 2, then the equation will have (x-3)^2 as a factor, indicating that 3 appears twice as a root.
4. What is the significance of identifying a repeated root in a characteristic equation?
Identifying a repeated root in a characteristic equation can help in determining the stability of a system described by the equation. If the root has a multiplicity greater than one, it can affect the behavior of the system and lead to different outcomes. It also helps in finding the general solution to the equation.
5. Can a characteristic equation have more than one repeated root?
Yes, it is possible for a characteristic equation to have more than one repeated root. This means that there can be multiple values of r that make (x-r) a factor of the equation. In this case, the equation will have (x-r)^k as a factor, where k is the multiplicity of the root r.
