MHB Show that the determinant is equal to 0
  • Thread starter Thread starter mathmari
    Determinant
mathmari
MHB
Hey! :o
Let $\alpha, \beta, \gamma$ be internal angles of an arbitrary triangle.
I want to show that $$\det \begin{pmatrix}\cos \beta & \cos \alpha&-1 \\ \cos\gamma & -1 & \cos\alpha \\ -1 & \cos\gamma & \cos\beta\end{pmatrix}=0$$
We have the following:
\begin{align*}&\det \begin{pmatrix}\cos \beta & \cos \alpha&-1 \\ \cos\gamma & -1 & \cos\alpha \\ -1 & \cos\gamma & \cos\beta\end{pmatrix}=\cos \beta \cdot \det \begin{pmatrix} -1 & \cos\alpha \\ \cos\gamma & \cos\beta\end{pmatrix}-\cos \alpha \cdot \det \begin{pmatrix} \cos\gamma & \cos\alpha \\ -1 & \cos\beta\end{pmatrix}+(-1)\cdot \det \begin{pmatrix} \cos\gamma & -1 \\ -1 & \cos\gamma \end{pmatrix} \\ & = \cos \beta \cdot \left (-\cos \beta-\cos\gamma\cdot \cos\alpha\right )-\cos \alpha \cdot \left (\cos\gamma\cdot \cos\beta-(-1)\cdot \cos\alpha\right )-\left (\cos^2 \gamma -(-1)^2\right ) \\ & =-\cos^2 \beta-\cos\gamma\cdot \cos\alpha\cdot \cos \beta-\cos\alpha\cdot \cos\gamma\cdot \cos\beta- \cos^2\alpha-\cos^2 \gamma +1 \\ & =1-2\cdot \cos\alpha\cdot \cos\beta\cdot \cos\gamma - \cos^2\alpha-\cos^2 \beta-\cos^2 \gamma \end{align*}
Do we use here the Law of cosines?
\begin{align*}&c^2=a^2+b^2-2ab\cdot \cos \gamma \Rightarrow \cos \gamma=\frac{a^2+b^2-c^2}{2ab} \\ &b^2=a^2+c^2-2ac\cdot \cos \beta \Rightarrow \cos \beta=\frac{a^2+c^2-b^2}{2ac} \\ &a^2=b^2+c^2-2bc\cdot \cos \alpha \Rightarrow \cos\alpha=\frac{b^2+c^2-a^2}{2bc}\end{align*}
Or how could we continue? (Wondering)
Hey mathmari! (Smile)
That should work I think although it looks like the expression will get pretty complicated first.
Alternatively we might try to use $α+β+γ=\pi$.
That is, substitute $γ=\pi-α-β$. (Thinking)
Do you mean $\cos \gamma=\cos (\pi -\alpha-\beta)=-\cos (\alpha+\beta )$ ? (Wondering)
That is what I was thinking yes.
I didn't try to calculate it manually though. It's just an alternative approach.
However, I did find that it is sufficient for Wolfram to conclude that it's zero, so it seems likely that filling it in by hand is feasible. (Thinking)
Another alternative approach is to try to find and find a geometric reason why the vectors are linearly dependent.
I didn't find one yet though. (Thinking)
mathmari said:
$$1-2\cdot \cos\alpha\cdot \cos\beta\cdot \cos\gamma - \cos^2\alpha-\cos^2 \beta-\cos^2 \gamma$$
Doesn't this expression have cyclic symmetry? Implying there is an extremum at $\cos\alpha=\cos\beta=\cos\gamma$? Then, applying La Grange multipliers to the general case $\alpha+\beta+\gamma=\pi$, we arrive at the desired result.
Thread 'Derivation of equations of stress tensor transformation'
Hello ! I derived equations of stress tensor 2D transformation. Some details: I have plane ABCD in two cases (see top on the pic) and I know tensor components for case 1 only. Only plane ABCD rotate in two cases (top of the picture) but not coordinate system. Coordinate system rotates only on the bottom of picture. I want to obtain expression that connects tensor for case 1 and tensor for case 2. My attempt: Are these equations correct? Is there more easier expression for stress tensor...
