MHB Show that the diophantine equation has only these solutions
  • Thread starter Thread starter evinda
The diophantine equation \(x^2+y^2=2\) has only four integer solutions: \((1,1), (1,-1), (-1,1), (-1,-1)\). The reasoning involves recognizing that both \(x^2\) and \(y^2\) must be non-negative and less than or equal to 2, leading to possible integer values of \(\pm 1\) and 0. However, only the combinations involving \(\pm 1\) satisfy the equation. The suggestion to use modulo reasoning is unnecessary, as the integer solutions can be derived straightforwardly. The incorrect solutions \((\pm 2, 0)\) do not satisfy the equation, confirming the validity of the identified solutions.
evinda
MHB
Hello! (Wave)
I want to show that the diophantine equation $x^2+y^2=2$ has only these solutions:
$$(x,y)=(1,1),(1,-1), (-1,1), (-1,-1)$$
That's what I have tried:
$$x^2+y^2=2 \Rightarrow x^2=2-y^2$$
$$x^2>0 \Rightarrow 2-y^2>0 \Rightarrow y^2<2 \Rightarrow -\sqrt{2}<y< \sqrt{2} \Rightarrow y=\pm 1,0$$
  • $y=0: x= \pm \sqrt{2} \notin \mathbb{Z}$
  • $y=\pm 1: x= \pm 1$
So, the solutions are $(\pm 1, \pm 1), (\pm 2,0)$.
Is it right? Could I also find the solutions, using modulo?
Also, how can I show that these solutions are the only ones? (Thinking)
Mathematics news on Phys.org
Are you sure you are asked to find integer solutions to $x^2 + y^2 = 2$? Is there any chance *rational* solutions were asked?
In the case of integers, it's trivially easy and you're overcomplicating it. $x^2 + y^2 = 2$ and $x^2, y^2$ are both positive (squares can't take negative values). Hence $x^2 \leq 2$ and $y^2 \leq 2$. The only possible integer values of $x$ and $y$ satisfying these are $(x, y) = (\pm 1, \pm 1), (\pm 1, 0), (0, \pm 1), (0, 0)$
And from all of them, only the first four $(\pm 1, \pm 1)$, i.e., $(1, 1), (-1, 1), (1, -1), (-1, -1)$ satisfies the equation. No modulo argument is needed.
EDIT : Oh I observed that you enumerated the wrong solutions $(x, y) = (\pm 2, 0)$. There doesn't work as $x^2 + y^2 = 4 + 0 \neq 2$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
