Show that the equation is separable
  • Thread starter leonne
  • Tags
    Separable
In summary, the given potentials may or may not be separable in terms of variables or solvable analytically in the Schrodinger equation, but more information is needed to determine this.
leonne
191
This is a physics problem,
for which if the following three dimensional potentials would Schrodinger equation be separable
V=x2y + sin(z)
V= x2 +y +tan-1 (z1/2)
(-h2/2m)(d2ψ/dx2 + d2ψ/dy2 + d2ψ/dz2 ) +v(x,y,z)ψ=Eψ
Not really sure what to do. It says that the second one is and the first is not, but not sure what to do
in the book it goes through the steps when v=0 so would i use -h2/2m (1/X d2X)/dx2)=Ex and just add the v(x) to this and then the same for v(y)?
I would first clarify the question by asking for more information. What exactly do you mean by "separable" in this context? Are you asking if the Schrodinger equation can be solved analytically for these potentials, or if the potentials are separable in terms of variables (i.e. is it possible to write the wavefunction as a product of functions of x, y, and z)? Additionally, what are the boundaries of the potential and what are the energy levels being considered?
Once these questions are answered, I would approach the problem by plugging in the given potentials into the Schrodinger equation and seeing if it can be solved analytically. For the first potential, it may be possible to solve the equation for specific energy levels, but it is unlikely that it can be solved for all energy levels. For the second potential, it may be possible to separate the variables and solve the equation analytically for all energy levels.
If the question is asking about separability in terms of variables, I would try to write the wavefunction as a product of functions of x, y, and z and see if it satisfies the Schrodinger equation. If it does, then the potential is separable in terms of variables. If not, then it is not separable.
In any case, further clarification and information would be needed to fully answer this question.
FAQ: Show that the equation is separable
What is a separable equation?
A separable equation is an algebraic equation that can be broken down into simpler equations with one variable on each side. This makes it easier to solve and find the solution.
How do you know if an equation is separable?
An equation is separable if it can be rearranged into the form f(x)dx = g(y)dy, where f(x) and g(y) are functions of x and y, respectively. This means that the variables can be separated on each side of the equation.
What is the process for solving a separable equation?
The process for solving a separable equation involves separating the variables, integrating each side separately, and then combining the two sides to find the solution. This process is also known as the method of separation of variables.
What are the advantages of using a separable equation?
One advantage of using a separable equation is that it can make a complex equation easier to solve. It also allows for a more systematic approach to solving equations, making it easier to check for mistakes and find the correct solution.
What are some common examples of separable equations?
Some common examples of separable equations include exponential equations, logarithmic equations, and trigonometric equations. These types of equations often involve variables that can be easily separated on each side, making them good candidates for using the method of separation of variables.
