Show that the given electric field is a plane wave
The discussion focuses on demonstrating that a given electric field represents a plane wave. It begins with the definition of a wavefront and the manipulation of the cosine argument to establish a relationship involving position and time. A participant identifies an error in the rearrangement of the equation but acknowledges that it resembles the scalar equation of a plane. The conversation confirms that the derived equation indeed indicates a plane wave, emphasizing the simplicity of the conclusion. Overall, the participants agree on the relationship between the equation and the characteristics of a plane wave.
Blanchdog
Show that each wavefront of the electric field forms a plane
## E(r, t) = E_0 \text{cos}(k(\hat{u} \cdot r - c t) + \phi)##
A wavefront is defined as a surface in space where the argument of the cosine has a constant value. So I set the argument of the cosine to an arbitrary constant s.
## k(\hat{u} \cdot r - c t) + \phi = s ##
The positional information is is in r, so I rearrange the equation to be
## \hat{u} \cdot r = \frac s k + ct + \phi = \text{const}##
## u_x x + u_y y + u_z z = \text{const} ##
And that's where I'm stuck.
You made a small error in the rearrangement, but once corrected the last line is almost right; that's the general equation of a plane of normal ##\hat{n}##, but ##\hat{u} \cdot r## depends on ##t## so isn't constant in time (that's why the plane translates).
Whoops you're right, I wasn't very careful with my minus signs since I knew it was all going to be wrapped up into a constant anyway.
It looks like my equation is in the form of the scalar equation of a plane... is it really that simple? I have the equation of a plane so it is a plane wave?
Likes DaveE and ergospherical
Yeah, pretty much 😄
Thread 'Correct statement about a reservoir with an outlet pipe'
The answer to this question is statements (ii) and (iv) are correct. (i) This is FALSE because the speed of water in the tap is greater than speed at the water surface (ii) I don't even understand this statement. What does the "seal" part have to do with water flowing out? Won't the water still flow out through the tap until the tank is empty whether the reservoir is sealed or not? (iii) In my opinion, this statement would be correct. Increasing the gravitational potential energy of the...
