Show that the given function is continuous
chwala
387
Show that the function ##f :\mathbb{C} → \mathbb{C} ## defined by ##f(z) = {\sqrt 3} i^2 |z|## is a continous function.
complex numbers.
Refreshing... going through the literature i may need your indulgence or direction where required. ...of course i am still studying on the proofs of continuity...the limits and epsilons... in reference to continuity of functions...
From my reading, A complex valued function is continous if and only if both its real part and imaginary part are continous.
Firstly
##f(z)= x+iy = -\sqrt 3 x^2 -\sqrt 3 y^2 i=u(x,y)+iv(x,y)##,that is from the concept under Cauchy-Riemann equations. Therefore, ##u(x,y)=-\sqrt 3 x^2## and ##v(x,y)=-\sqrt 3 y^2## of which both ## u(x,y)## and ##v(x,y)## are continous.
How did you get this:
##-\sqrt 3 x^2 -\sqrt 3 y^2 i##
##|z| = |x+iy| = x^2+y^2## unless i am missing something...
It does not answer my question AND this is incorrect.
Likes chwala
okay...am back to the drawing board...later. I am missing the square root sign...typo...let me take a break.
##\sqrt{x^2 + y^2}##
From where i left, i have
##f(z)=\sqrt 3 ⋅ i^2|z|=-\sqrt 3 |x+iy| = -\sqrt 3 {\sqrt{x^2 + y^2}}##
We know that ##z=x+iy## therefore using the cauchy Riemann equations we shall
let ##u(x,y) =x## and ##v(x,y)=iy##
then,
##u_x= -\dfrac{\sqrt{3}}{2} ⋅(x^2+y^2)^{-0.5}⋅ 2x= -\dfrac{2x\sqrt{3}}{2\sqrt{x^2+y^2}} =-\dfrac{\sqrt{3}x}{\sqrt{x^2+y^2}}## and
##u_y= -\dfrac{\sqrt{3}}{2}⋅ (x^2+y^2)^{-0.5} ⋅2y=-\dfrac{2y\sqrt{3}}{2\sqrt{x^2+y^2}}=-\dfrac{\sqrt{3}y}{\sqrt{x^2+y^2}}##
##u(x,y)## is continous and ##v(x,y)## is continous and therefore ##f(z)## will be continous.
I don't understand what it means and don't see you using it anywhere.
chwala said:
Homework Statement: Show that the function ##f :\mathbb{C} → \mathbb{C} ## defined by ##f(z) = \sqrt 3 i^2 |z|## is a continous function.
Relevant Equations: complex numbers.
Use the definition of continuity directly. [itex]f : \mathbb{C} \to \mathbb{C}[/itex] is continuous at [itex]w \in \mathbb{C} [/itex] iff for every [itex]\epsilon > 0[/itex] there exists [itex]\delta > 0[/itex] such that for every [itex]\mathbb{z} \in \mathbb{C}[/itex], if [itex]|z - w| < \delta[/itex] then [itex]|f(z) - f(w)| < \epsilon[/itex]. Consider that [tex]
|z| = |z - w + w| \leq |z - w| + |w|[/tex] and [tex]
|w| = |w - z + z| \leq |w - z| + |z|.[/tex] Hence [tex]
||z| - |w|| \leq |z - w|.[/tex]
Likes chwala
Can I let ##w=0##. This is an area I need to study...and are you implying one cannot use the Cauchy Riemann equations?
No. The only requirement on w is that ##|z-w|<\delta##.it should be clise to whatever z you want to show continuity at.
Alternatively just show that the preimage of any open set is an open set. That should be pretty straightforward.
Likes chwala
Alternatively, we see that ##f## is a composition of polynomial and modulus, both of which are continuous.
Cauchy-Riemann stuff is relevant for complex differentiability.
Likes chwala
You don't have braces around the square root radicand.
Do you mean this -- ##\sqrt 3 \cdot i^2 |z|##?
Or this -- ##\sqrt{3 i^2}|z|##?
The first would simplify to ##-\sqrt 3 |z|## and the second would simplify to ##\sqrt{-3}|z| = i\sqrt 3 |z|##.
It should be very simple to show continuity for either one.
Regarding TeX, keep in mind that if what comes after an operator is a single character, you can omit braces, but if what follows is two or more characters, braces are necessary.
For example, I can omit braces to write ##x^2## (unrendered this is ##x^2##), but braces are needed for ##x^{-1}## (unrendered: ##x^{-1}##). Without braces, this comes out as ##x^-1##; i.e., the 1 doesn't get rendered as a superscript.
If your ##i^2## refers to the Complex number ##i##, then your map is actually ##\mathbb R##- valued. As such, it's a product of continuous functions.
yes, the ##i## refers to the complex number.
The first one...
chwala said:
The first one...
Then you want to write it as ##\sqrt{3 i^2}|z| = \sqrt{-3}|z| = i\sqrt 3 |z|##. I assume you know how to right click on the above to show the TeX that I wrote.
Edit: I mistook what the first one was. That one should have been written as ##-\sqrt 3 i^2|z| = -\sqrt 3 |z|##.
Likes chwala
My friends, I
The first one was this:
Yes @Orodruin , sorry I was unable initially to put parenthesis...but @Mark44 advised how to do it .. I didn't want to amend original post following the threads...
Fixed in my post... Thanks for pointing this out!
forgive me if I misunderstand the question. either you want to know how to give a formal proof of continuity, or to understand why it is true. In my opinion, if you understand why, you have a better chance of giving a proof, so I address that.
Continuity means that whenever the inputs are close, the outputs are also close.
'first consider the function |z|. Note that |z| is the distance from z to the origin. thus one must show that if z is close to w, then z is almost as close to the origin as w. This is called the triangle inequality.
I.e. the distance from z to the origin is less than the sum of the distance from w to the origin plus the distance from z to w. Thus if z is near w, then z is almost as close to the origin as w.
Likes chwala
The question is a past exam question -Analysis paper. The question is written as it is on the paper.
forgive me, I assumed you wanted to understand it. that is what I am addressing.
Likes chwala
I really appreciate it @mathwonk ...my undergraduate professors rushed on the chapters to do with Analysis plus I didn't put much work afterwards..I just have to self study... Cheers man.
This is a very strange question! Clearly the constant ##\sqrt{3}i^2## plays no role, why is it discussed so much! So the question is to show that ##f(z)=|z|## is continuous. Isn't this obvious given what continuous means! May be you can start with the definition of continuous you use.
If your function is ##f(z)=|z|##, then you can check whether the inverse image of an open set is open. It will depend on your domain, range. In this case, ##|z|## is Real-valued. An open interval##(a,b)## would have as an inverse image all circles of radius ##r; a<r<b##.
I tried to hint at this, but OP didn't seem to bite:
It should be added that the shape of the preimage is called an annulus.
Likes chwala and WWGD
I am following the steps slowly 😄...
FAQ: Show that the given function is continuous
What does it mean for a function to be continuous?
A function is continuous at a point if the limit of the function as it approaches that point is equal to the function's value at that point. Mathematically, a function f(x) is continuous at x = c if lim (x → c) f(x) = f(c). For the function to be continuous over an interval, it must be continuous at every point within that interval.
How do you show that a function is continuous at a specific point?
To show that a function is continuous at a specific point x = c, you need to verify three conditions: (1) f(c) is defined, (2) the limit of f(x) as x approaches c exists, and (3) the limit of f(x) as x approaches c is equal to f(c). If all three conditions are met, the function is continuous at that point.
What are common techniques used to prove continuity?
Common techniques to prove continuity include: (1) Direct substitution for polynomial and rational functions, (2) Using limit laws and properties for more complex functions, (3) Applying the epsilon-delta definition of a limit for rigorous proofs, and (4) Utilizing known continuous functions and theorems, such as the Intermediate Value Theorem, to extend continuity to new functions.
Can piecewise functions be continuous, and how do you prove it?
Yes, piecewise functions can be continuous. To prove it, you need to check the continuity at each piece and at the boundaries where the pieces meet. This involves verifying that the limit from the left-hand side equals the limit from the right-hand side and that both are equal to the function's value at the boundary points.
What role do discontinuities play in determining the continuity of a function?
Discontinuities are points where a function is not continuous. There are several types of discontinuities: removable (where the limit exists but does not equal the function's value), jump (where the left-hand and right-hand limits differ), and infinite (where the function approaches infinity). Identifying and understanding these discontinuities is crucial in analyzing and proving the overall continuity of a function.
