Show that the matrix D is invertible
  • MHB
  • Thread starter mathmari
  • Tags
    Matrix
In summary, we discussed the relationship between a symmetric and positive definite matrix $C$ and another matrix $D$. We showed that $D^TCD$ is positive definite if and only if $D$ is invertible. For the proof, we used the properties of positive definite matrices and the fact that $C$ is positive definite. We also discussed how setting $Dx=y$ can help us prove the direction $\Leftarrow$.
mathmari
MHB
5,049
Hi! :eek:
Given that $C \in \mathbb{R}^{n,n}$ is symmetric and positive definite and $D \in \mathbb{R}^{n,n}$.
I have to show that $D^TCD$ is positive definite $\Leftrightarrow $ $D$ is invertible.
For the direction $\Rightarrow $:
$D^TCD$ is positive definite, that means that $\forall x \in \mathbb{R}^n\setminus \{0\} :$ $ x^T D^TCD x >0$.
How can I continue?
mathmari said:
Hi! :eek:
How can I continue?
Heya! ;)
Suppose $D$ is not invertible. Then there must be some $x$ for which $Dx = 0$...
I like Serena said:
Heya! ;)
So for some $x$ for which $Dx = 0$: $x^TD^TCDx=0$, but it should be $x^TD^TCDx>0$.
So $D$ must be invertible. Right?
For the direction $\Leftarrow $:
$D$ is invertible, so $Dx=0 \Rightarrow x=0$
To show that $D^TCD$ is positive definite, we have to show that $x^TD^TCDx>0$ $\forall x \in \mathbb{R}\setminus \{0\}$.
$\forall x \in \mathbb{R}\setminus \{0\}$ we have that $Dx \neq 0 \Rightarrow x^TD^TCDx \neq 0$. But how can we conclude that this is greater than $0$?
Right! :cool:
Well, it is given that $C$ is positive definite.
So for each $y \ne 0$ we have that $y^T C y > 0$.
Now suppose we set $Dx=y$...
I like Serena said:
Right! :cool:
Great! Thank you very much! :eek:
FAQ: Show that the matrix D is invertible
How do I know if a matrix is invertible?
A matrix is invertible if its determinant is not equal to zero. This means that there exists a unique solution to the system of linear equations represented by the matrix.
What is the significance of a matrix being invertible?
An invertible matrix has many important applications, such as solving systems of linear equations, finding the inverse of a matrix, and calculating determinants. It also plays a key role in various mathematical and scientific fields, such as physics, engineering, and computer science.
Can a matrix be invertible if it has a zero determinant?
No, a matrix with a zero determinant is not invertible. This is because a zero determinant indicates that the matrix does not have a unique solution to the system of equations it represents, and therefore cannot be inverted.
How can I prove that a matrix is invertible?
To prove that a matrix is invertible, you can use various methods such as the Gauss-Jordan elimination method, finding the determinant of the matrix, or using the inverse matrix formula. If the result of any of these methods is a non-zero value, then the matrix is invertible.
Is every square matrix invertible?
No, not all square matrices are invertible. Only square matrices with a non-zero determinant are invertible. If a square matrix has a zero determinant, then it is not invertible. Additionally, only square matrices with the same number of rows and columns can be inverted.
