Show that the point satisfies the conditions
In summary: It's sloppy usage of the wording "maximum coordinate".Apparently what is intended is the "maximum size of a coordinate" or the "magnitude of a coordinate" or the "absolute value of a coordinate".
mathmari
MHB
5,049
Hey! :eek:
A round membrane in space, is over the space $x^2+y^2 \leq a^2$.
The maximum coordinate $z$ of a point of the membrane is $b$.
We suppose that $(x, y, z)$ is a point of the inclined membrane.
Show that the respective point $(r , \theta , z)$ in cylindrical coordinates satisfies the conditions $$0 \leq r \leq a \ , \ \ 0 \leq \theta \leq 2 \pi \ , \ \ |z| \leq b$$
Could you give me some hints how we could show that??
I have done the following:
Using cylindrical coordinates we get $r=\sqrt{x^2+y^2}=\leq |a|$ and sonve $r \geq 0$ we have $0 \leq r \leq a$.
From the defintion of cylindrincal coordinates we have that $0 \leq \theta \leq 2 \pi$,
But how do we get that $|z| \leq b$??(Wondering) By the sentence "The maximum coordinate $z$ of a point of the membrane is $b$" ?? (Wondering)
Hey! (Smile)
Good! :)
The sentence "The maximum coordinate $z$ of a point of the membrane is $b$" means the following.
Suppose we have a point on the membrane with coordinate $z$.
Then the size of that coordinate $z$ has a maximum of $b$.
Let the membrane be given by some function $f$ such that:
$$z=f(x,y)$$
with a domain given by $x^2+y^2\le a$.
Then:
$$\text{The maximum (size of the) coordinate z} = |\max_{x^2+y^2\le a} z| = |\max_{x^2+y^2\le a} f(x,y)| = b$$
$$z=f(x,y)$$
Then:
I haven't understood why it stands that $|\max_{x^2+y^2\le a} f(x,y)| = b$ and not $\max_{x^2+y^2\le a} f(x,y) = b$. Could you explain it to me ?? (Wondering)
Apparently what is intended is the "maximum size of a coordinate" or the "magnitude of a coordinate" or the "absolute value of a coordinate". (Nerd)
FAQ: Show that the point satisfies the conditions
What does it mean to "show that the point satisfies the conditions"?
Showing that a point satisfies the conditions means proving that the coordinates of the point meet the given requirements or constraints. This can be done through mathematical calculations, equations, or logical reasoning.
Why is it important to show that a point satisfies the conditions?
It is important to show that a point satisfies the conditions because it provides evidence that the point is a valid solution to a problem or equation. Without this proof, the point may not be considered a viable option.
How can I show that a point satisfies the conditions?
The method for showing that a point satisfies the conditions will depend on the specific conditions given. Some common approaches include substituting the coordinates of the point into equations, using geometric principles, or using logical arguments.
Can a point satisfy multiple conditions?
Yes, a point can satisfy multiple conditions. However, it is important to carefully consider all conditions and ensure that the point meets all of them in order to be a valid solution.
What if I cannot show that a point satisfies the conditions?
If you cannot show that a point satisfies the conditions, it may indicate that the point is not a valid solution. You may need to revise your approach or consider other points that may satisfy the conditions.
