MHB Show that the tridiagonal matrix is positive definite
  • Thread starter Thread starter mathmari
    Matrix Positive
The discussion focuses on proving that the tridiagonal matrix A is positive definite. The key steps involve calculating the expression ⟨x, Ax⟩ and showing it is non-negative. The participants suggest expressing the result as a sum of squares, which guarantees non-negativity and indicates that equality holds only when the vector x is the zero vector. The conclusion reached is that ⟨x, Ax⟩ is greater than or equal to zero, and equals zero if and only if x is the zero vector. This confirms that the matrix A is indeed positive definite.
mathmari
MHB
Hey! :o
We have the tridiagonal matrix $A=\begin{pmatrix}2 & 1 & \ldots & 0 \\ 1 & 2 & 1 & \ldots \\ \ldots & \ldots & \ldots & \ldots \\ 0 & \ldots & 1 & 2\end{pmatrix}$. I want to show that it is positive definite.
For that it is given the following hint:
1) $\langle x, Ax\rangle \geq 0$
2) $\langle x, Ax\rangle =0 \Rightarrow x=0$ I have done the following:
The $i$-th component of the vector $Ax$ is \begin{equation*}(Ax)_i=x_{i-1}+2x_i+x_{i+1} , \ i=1, 2, \ldots , n \ \text{ with } x_0=x_{n+1}=0\end{equation*}
Then we have the following: \begin{equation*}\langle x, Ax\rangle=\sum_{i=1}^nx_i(Ax)_i =\sum_{i=1}^nx_i\left (x_{i-1}+2x_i+x_{i+1}\right )=\sum_{i=1}^nx_i x_{i-1}+2\sum_{i=1}^n x_i^2+\sum_{i=1}^n x_ix_{i+1}\end{equation*}
Is everything correct so far? (Wondering)
Now we have to show that it is positive if the vector $x$ is not the zero vector and equal to $0$ if the vector is the zero vector, right? But how can we do that? (Wondering)
Mathematics news on Phys.org
mathmari said:
Hey! :o
Hey mathmari!
How about trying to write it as a sum of squares?
That is, something like $(x_1+x_2)^2 + (x_2 + x_3)^2 + ...$.
Squares are always $\ge 0$ aren't they?
With equality only if all squares are $0$? (Wondering)
Ahh so we have the following, don't we?
\begin{align*}\langle x, Ax\rangle&=\sum_{i=1}^nx_i(Ax)_i \\ & =\sum_{i=1}^nx_i\left (x_{i-1}+2x_i+x_{i+1}\right )\\ & =\sum_{i=1}^nx_i x_{i-1}+2\sum_{i=1}^n x_i^2+\sum_{i=1}^n x_ix_{i+1} \\ & =x_1 x_{0}+\sum_{i=2}^nx_i x_{i-1}+2\sum_{i=1}^n x_i^2+\sum_{i=1}^{n-1} x_ix_{i+1} +x_nx_{n+1} \\ & =\sum_{i=2}^nx_i x_{i-1}+2\sum_{i=1}^n x_i^2+\sum_{i=1}^{n-1} x_ix_{i+1} \\ & = \sum_{i=1}^{n-1}x_i x_{i+1}+2\sum_{i=1}^n x_i^2+\sum_{i=1}^{n-1} x_ix_{i+1} \\ & = 2\sum_{i=1}^{n-1}x_i x_{i+1}+2\sum_{i=1}^n x_i^2 \\ & = \left (\sum_{i=1}^{n-1} x_i^2+x_n^2\right )+2\sum_{i=1}^{n-1}x_i x_{i+1}+\left (x_1^2+\sum_{i=2}^n x_i^2\right ) \\ & = \sum_{i=1}^{n-1} x_i^2+2\sum_{i=1}^{n-1}x_i x_{i+1}+\sum_{i=2}^n x_i^2+x_1^2+x_n^2 \\ & = \sum_{i=1}^{n-1} x_i^2+2\sum_{i=1}^{n-1}x_i x_{i+1}+\sum_{i=1}^{n-1} x_{i+1}^2+x_1^2+x_n^2 \\ & = \sum_{i=1}^{n-1} \left (x_i^2+2x_i x_{i+1}+ x_{i+1}^2\right )+x_1^2+x_n^2 \\ & = \sum_{i=1}^{n-1} \left (x_i+ x_{i+1}\right )^2+x_1^2+x_n^2 \end{align*}
So we get $$\langle x, Ax\rangle \geq 0 \ \text{ and } \ \langle x, Ax\rangle=0 \iff x_i=0 \ \forall i \iff x=0$$
(Wondering)
(Wondering)
(Nod)
(Nod)
Thank you! (Yes)
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
