Show that the vector has zero divergence
In summary, the vector v = (r-hat) over (r squared) has zero divergence and zero curl for r not equal to 0. The r-component of the gradient operator in spherical coordinates is d/dr, while the divergence operator is different. The r^2 term in the equation 1/(r^2) * (r^2 * v_r) comes from the metric coefficients in spherical coordinates.
dizewarrior
v = [itex]\frac{\hat{r}}{r2}[/itex] (not sure why formatting isn't working?)
has zero divergence (it is solenoidal) and zero curl (it is irrotational) for r not equal to 0
div(V) = (d/dx)V_x + (d/dy)V_y + (d/dz)V_z
I used del operator in spherical (the r component being (d/dr)) and it didn't seem to work?
for curl i was able to get curl(v) = 0
I've tried converting v to cartesian and using the cartesian del operator but it didn't work either
I'm stuck at this point =\
dizewarrior said:
v = [itex]\frac{\hat{r}}{r^2}[/itex] (not sure why formatting isn't working?)
Don't use the BBcode tags within LaTeX mark-up.
Also, if you're going to use LaTeX, use it for the whole equation instead of bits and pieces. It's easier to type, and it'll look better.
Also, you might need to refresh your screen to get the LaTeX to work.
thanks everyone!
few questions though,
1) where can I find a guide on posting LaTeX code on the forums?
2) does the 1/(r^2) * (r^2 * v_r): does the r^2 come from metric coefficients?
dizewarrior said:
thanks everyone!
1) See https://www.physicsforums.com/showthread.php?t=386951 to get started.
2) I'm not sure what you mean by metric coefficients. These factors show up for similar reasons as to why the volume element in spherical coordinates is r2 sin(theta). A vector calculus book should explain it in the section about grad, div and curl in different coordinate systems. Maybe even the wiki page I linked to earlier explains it?
FAQ: Show that the vector has zero divergence
What does it mean for a vector to have zero divergence?
Zero divergence means that the vector field has no sources or sinks, and the flow of the vector is neither expanding nor contracting at any point in space. This can also be thought of as the vector field having a constant flow rate at every point.
How is divergence of a vector calculated?
Divergence of a vector is calculated using the divergence operator, which is represented by the symbol ∇ ·. It is a mathematical operation that takes the partial derivatives of each component of the vector field with respect to each spatial dimension and sums them together.
Can a vector have both zero divergence and non-zero curl?
Yes, it is possible for a vector field to have zero divergence and non-zero curl. This is known as an irrotational vector field and it typically occurs in 2D vector fields. In this case, the vector field has no sources or sinks and the flow of the vector is circulating around a central point.
How is zero divergence related to the conservation of mass?
Zero divergence is closely related to the conservation of mass, as it reflects the idea that the amount of fluid entering a certain region of space is equal to the amount of fluid exiting that region. In other words, the flow of a vector field with zero divergence is incompressible and mass is conserved.
What are some real-world applications of zero divergence vectors?
Zero divergence vectors have many applications in physics and engineering. For example, they are used to model fluid flow in pipes, air flow around an airplane wing, and the magnetic field around a magnet. In each of these scenarios, the vector field has zero divergence because mass, air, and magnetic field lines cannot be created or destroyed.
