Show that x+y+z≥√[((x+1)(y+2)(z+2))/(3)]
  • MHB
  • Thread starter anemone
In summary, the given equation represents a mathematical inequality where the sum of three variables (x, y, and z) is greater than or equal to the square root of the product of the same three variables plus 1 and 2, divided by 3. This inequality can be proved using the Cauchy-Schwarz inequality and has practical applications in fields such as physics, engineering, and economics. There are various methods to solve inequalities like this one, including algebraic manipulation, graphing, and solving related equations.
anemone
MHB
POTW Director
3,883
115
Let $x,\,y,\,z$ be positive real numbers satisfying $xyz=1$.
Show that $x+y+z\ge \sqrt{\dfrac{(x+2)(y+2)(z+2)}{3}}$.
Mathematics news on Phys.org
Show that $x+y+z\ge \sqrt{\dfrac{(x+2)(y+2)(z+2)}{3}}---(1)$.
let :$x,y,z $ be the roots of :$ t^3-at^2+bt-1=0 (here \ \, x,y,z>0)$
we have :$a=x+y+z\geq 3---(2)$
and $b=xy+yz+zx\geq 3---(3)$
$xyz=1---(4)$
also $a^2 - 2b \geq 3---(5)$
if (1) is true we only have to prove :$3a^2\geq 9+4a+2b----(*)$
from (2)(3)(5) it is easy to see (*) is true ,
and the proof is done
$xyz=1---(4)$
uanble to follow
kaliprasad said:
uanble to follow
$a^2-2b=(x+y+z)^2-2(xy+yz+zx)$
$=x^2+y^2+z^2\geq 3\sqrt[3]{x^2y^2z^2}=3$
using:$AP\geq GP$
$xyz=1---(4)$
Thanks Albert for participating and the solution that I want to show you and MHB is more or less using the same method as you:
First, we apply AM-GM to $a^2$ and 1 and we get: $a^2+1\ge 2\sqrt{a^2}\ge 2a$
We repeat this for $b$ and $c$ and add the resulting inequalities yields
$a^2+b^2+c^2+3\ge 2(a+b+c)$---(1)
Next, apply AM-GM to $ab,\,bc,\,ac$ gives us $ab+bc+ac\ge 3\sqrt[3]{(abc)^2}\ge 3$---(2) since $abc=1$.
Again, by AM-GM applying on $a^2,\,b^2,\,c^2$ we have $a^2+b^2+c^2\ge 3\sqrt[3]{(abc)^2}\ge 3$---(3) since $abc=1$.
Now, we add $2\times (1)+4\times (2)+(3)$ and that gives
$3(a^2+b^2+c^2)+4(ab+bc+ac)\ge 4(a+b+c)+9$
Add $2(ab+bc+ac)$ to both sides of the inequality above gives
$3(a^2+b^2+c^2)+6(ab+bc+ac)\ge 2(ab+bc+ac)+4(a+b+c)+9$
$3((a^2+b^2+c^2)+2(ab+bc+ac))\ge (a+2)(b+2)(c+2)$
$3(a+b+c)^2\ge (a+2)(b+2)(c+2)$
$a+b+c\ge \sqrt{\dfrac{(a+2)(b+2)(c+2)}{3}}$ (Q.E.D.)
FAQ: Show that x+y+z≥√[((x+1)(y+2)(z+2))/(3)]
What does the equation "x+y+z≥√[((x+1)(y+2)(z+2))/(3)]" represent?
This equation represents a mathematical inequality, where the sum of three variables (x, y, and z) is greater than or equal to the square root of the product of the same three variables plus 1 and 2, divided by 3.
How can you prove that this inequality is true?
There are multiple ways to prove this inequality. One way is to use the Cauchy-Schwarz inequality, which states that for any two vectors a and b, the dot product of a and b is less than or equal to the product of their magnitudes. In this case, we can consider the vectors (x, y, z) and (1, 2, 2) and use the Cauchy-Schwarz inequality to show that the left side of the original inequality is greater than or equal to the right side.
Can you provide an example to illustrate this inequality?
Sure. Let's say x = 2, y = 3, and z = 4. Plugging these values into the original inequality, we get 2+3+4≥√[((2+1)(3+2)(4+2))/(3)]. Simplifying, we get 9≥√[90/3], which is true since 9 is greater than or equal to 5.
What are the practical applications of this inequality?
This inequality has many practical applications in fields such as physics, engineering, and economics. For example, it can be used to prove stability conditions in mechanical systems, optimize production processes, and determine the optimal price for a product in a competitive market.
Is there a specific method to solve inequalities like this one?
Yes, there are several methods to solve inequalities like this one. Some common methods include using algebraic manipulation, graphing, or solving a related equation. The most appropriate method may vary depending on the complexity of the inequality and the context in which it is being used.
