Show that you can distribute powers to commuting elements
  • Thread starter Mr Davis 97
  • Tags
    Elements
In summary, the conversation discusses proving the statement that if a and b are commuting elements of G, then (ab)^n = a^n b^n for all n in the integers. The conversation includes the attempt at a solution, which involves proving two lemmas and using induction to prove the result for both positive and negative integers. Other possible approaches are also mentioned, such as showing that commuting of a and b gives ab^-1 = b^-1a, which can be used to derive the desired results. The conversation also raises the question of whether or not the lemmas were necessary to prove the statement.
Mr Davis 97
1,462
44
If ##a## and ##b## are commuting elements of ##G##, prove that ##(ab)^n = a^nb^n## for all ##n \in \mathbb{Z}##.
We prove two lemmas:
1) If ##a## and ##b## commute, then so do their inverses: ##ab=ba \implies (ab)^{-1} = (ba)^{-1} \implies b^{-1}a^{-1} = a^{-1}b^{-1}##.
2) If ##a## and ##b## commute, then ##b^n a = ab^n##: Base case is trivial. Suppose for some ##k## we have ##b^ka = ab^k##. Then ##b^{k+1}a = bb^ka = bab^k = abb^k = ab^{k+1}##.
Now to the actual result.
Clearly ##(ab)^0 = a^0b^0##. So first we prove the result for the positive integers, by induction. The base case is trivial. Suppose for some ##k \in \mathbb{Z}^+## we have ##(ab)^k = a^kb^k##. Then ##(ab)^{k+1} = (ab)^k(ab) = a^kb^kab = a^kab^kb = a^{k+1}b^{k+1}##.
Now we prove the result for negative integers. ##(ab)^{-n} = (b^{-1}a^{-1})^n = (a^{-1}b^{-1})^n = (a^{-1})^n(b^{-1})^n = a^{-n}b^{-n}##.
Does this argument work? Were the lemmas really necessary or could I have assumed they held since their proofs are trivial?
So is the whole statement you have to show. Better to show it explicitly.
There is another argument, why you will not need to prove the negative ones explicitly: If you prove the statement for all ##n \in \mathbb{N}_0## and for all ##a,b \in G##, then you have also proven it for inverse elements. This is in words what you have written.
To do it by induction is a very formal way to prove it. In cases like the above, some dots will equally be acceptable, although from a logical point of view certainly not sufficient. But with the dots, every reader knows how the induction goes.
Likes Mr Davis 97
But isn't it the case that I am not proving for all ##a,b \in G##, rather just in the case ##a,b## commute?
Yes, sure. But that doesn't change by taking the inverses: they commutate if and only if ##a## and ##b## do.
Likes Mr Davis 97
another approach, that is of course closely related, is to show that commuting of ##a## and ##b## gives you
##ab^{-1} = b^{-1}a## (and ditto for ##ba^{-1} = a^{-1}b##),
from here you can derive all the results you want by the ability to 'multiply by 1' (identity)
Related to Show that you can distribute powers to commuting elements
1. What does it mean to distribute powers to commuting elements?
When we say that we can distribute powers to commuting elements, we mean that we can apply a power to each element within a set, and the order of those elements does not affect the outcome. In other words, the elements in the set "commute" or can be rearranged without changing the result.
2. Why is it important to be able to distribute powers to commuting elements?
This property is important in mathematics because it allows us to simplify expressions and make calculations easier. It also helps us to identify patterns and relationships between different elements within a set.
3. How can you prove that you can distribute powers to commuting elements?
To prove that we can distribute powers to commuting elements, we must show that the order of the elements in the set does not affect the outcome. This can be done through mathematical induction or by using specific examples to demonstrate the property.
4. What are some examples of sets where powers can be distributed to commuting elements?
Some common examples include sets of numbers (such as integers, rational numbers, or real numbers), matrices, and polynomials. However, this property can apply to any set of elements that commute with each other.
5. Can powers always be distributed to commuting elements?
No, not all sets have the property of being able to distribute powers to commuting elements. For example, the set of non-commuting matrices does not have this property. It is important to check if a set has this property before attempting to distribute powers to its elements.
