MHB Show Triangle ABC Similarity Type Independence of B,C
  • Thread starter Thread starter mathmari
    Type
The discussion revolves around demonstrating that the similarity type of triangle ABC is independent of the positions of points B and C on circles K and L, respectively. Participants clarify that the similarity type refers to the angles of the triangle remaining constant regardless of the locations of B and C. They conclude that due to the Inscribed Angle Theorem, the angles at points B and C will remain the same as long as point A is fixed, ensuring that triangles ABC and AB'C' are similar. Additionally, they explore how the length of the chord BD remains constant, reinforcing the independence of triangle similarity from the specific positions of B and C. The conversation effectively illustrates the geometric principles at play in this scenario.
mathmari
MHB
Hey! :o
Let K,L be circles with exactly two intersection points S and A. Let $C\in L$ and $B\in K$ with $C,B\neq S,A$. I want to show the similarity type of the triangle ABC is independent of the place of B and C.
Could you explain to me what I am supposed to show?
Mathematics news on Phys.org
Hey mathmari! (Smile)
Can you clarify what a similarity type of a triangle is?
Google doesn't seem to help.
I thought it might be the type of triangle, but whichever type we pick (equilateral. isoscales, scalene, acute, oblique, or right), we can draw circles through their corners.
And that would meet the conditions. (Thinking)
I think that it is meant that a triangle ABC is always similar to an other triangle AB'C' no matter where B or B' are on the circle K and where C or C' are on the circle L.
So, do we have to consider two such triangles ans show that they are similar? (Wondering)
Well, if we make a drawing, I think we can immediately see that given a triangle ABC, if we pick B somewhere else, that it will not be similar. (Worried)
I thought now the following:
Given that AS is fixed we have that the angle of C will be the same no matter where it is on the circle, so Angle(C)=Angle(C').
The same holds also for B, i.e., Angle(B)=Angle(B').
Since Angle(C)=Angle(C') and Angle(B)=Angle(B'), we conclude that the two triangles ABC and AB'C' have all angles the same, and they are similar.
So, we conclude that all triangles are similar no matter where B and C are.
Is this correct? (Wondering)
Is this correct?
Aha! So we would have the extra restriction that S must be on BC.
Let me give that a try:
\begin{tikzpicture}[ultra thick]
\def\rK{3};
\def\rL{2};
\path
(0,0) coordinate (K)
+(30:\rK) coordinate (A) node[above] {A}
+(-30:\rK) coordinate (S) node[below] {S}
+(315:\rK) coordinate (C)
+(195:\rK) coordinate (C')
(4,0) coordinate (L)
+(60:\rL) coordinate (B)
+(-60:\rL) coordinate (B')
\draw (K) circle (\rK) (L) circle (\rL);
\draw[orange] (A) -- (B) node[above right] {B} -- (C) node
{C} -- cycle;
\draw[cyan] (A) -- (B') node[below right] {B'} -- (C') node
{C'} -- cycle;
\end{tikzpicture}
Yep. Looks as if that would work. (Happy)
Why would the angle at C be the same as the angle at C'? (Wondering)​
Isn't it because all the angles over the arc $AS$ on the circle are the same? (Wondering)
Ah yes, the Inscribed angle theorem.
Then it's all good! (Nod)
(Nerd) (Yes)
If $CA$ intersects the circle $K$ at a second point $D$, how can we show that the length of $\overline{BD}$ is independent of the choice of $B$ and $C$ ? (Wondering)
Could you give me a hint? (Wondering)
We have the following drawing:
If we consider the arc $\overline{BD}$ we have that that angle $A$ is always the same (from the first question). Do we get from that the arc must also be the same? (Wondering)
Yes. I believe so.
Since we know that the angle $A$ is always the same, it follows by applying the Inscribed angle theorem in reverse, that the chord $BD$ always has the same length. Consequently the arc $BD$ will also always have the same length. (Thinking)
I like Serena said:
Yes. I believe so.
I see! Thank you very much! (Sun)
