Showing something is a subgroup
  • Thread starter kathrynag
  • Tags
    Subgroup
In summary, to show that s(a)=a is a subgroup of Sym(S), you need to show that it satisfies the three criteria of subgroup: having an inverse, being closed under the group operation, and the inverse being in the subgroup. In this case, it is sufficient to show that a in H, b in H implies ab-1 is in H, and that for any bijections f and g from S to S, f(a)=a and g(a)=a implies f(g(a))=a.
kathrynag
598
Let S be a set and let a be a fixed element of S. Show that s is an element of Sym(S) such that s(a)=a is a subgroup of Sym(S).
I guess I need to show associativity, having and identity, and there being an inverse, but am unsure how to.
The Symmetric group is already known to be a group so you do not need to show associativity. In general to show a subset H is a subgroup you need:
1) The inverse is in H
2) H is closed under the group operation (a,b in h implies ab in H).
3) If a is in H then a-1 is in H
however 2 and 3 imply 1 so you only really need to show the last two. The one step solution is to show that a in H, b in H implies ab-1 is in H because that implies 2 and 3. In your case let f,g be bijections from S to S. Then show:
1) f(a) = a implies f-1(a) =a
2) f(a) = a, g(a) =a implies f(g(a)) = a
FAQ: Showing something is a subgroup
What is a subgroup?
A subgroup is a subset of a group that itself forms a group under the same operation as the original group. In other words, it contains elements that are closed under the group operation and inverse.
How do you show that something is a subgroup?
To show that something is a subgroup, you must prove that it meets the three criteria of being closed under the group operation, containing the identity element, and containing the inverse of each element.
What is closure under the group operation?
Closure under the group operation means that when two elements in the subgroup are combined using the group operation, the result is also an element within the subgroup.
Why is it important to show that something is a subgroup?
Showing that something is a subgroup allows us to better understand the group structure and properties. It also allows us to make connections between different groups and their subgroups.
Can a subgroup have a different identity element than the original group?
No, a subgroup must have the same identity element as the original group. This is because if the identity element is not the same, the subgroup would not be closed under the group operation and therefore would not be a subgroup.
