Showing that a certain summation is equal to a Dirac delta?
The discussion focuses on proving that a specific summation involving bosonic creation and annihilation operators is equivalent to a Dirac delta function. The derivation begins with the expression involving the exponential terms and the commutation relation, leading to the need to show that the sum equals zero when the spatial points differ and integrates to one when they are the same. The periodicity of the exponential function is highlighted as crucial for demonstrating that terms cancel out when x does not equal y. The final conclusion affirms that the summation indeed results in the Dirac delta function, confirming the conceptual correctness of the derivation. The author seeks feedback on the rigor of their approach and its alignment with established principles in quantum field theory.
GCUEasilyDistracted
Quantum Field Theory for the Gifted Amateur Exercise 3.1 (reworded a bit): Suppose we are working with a system defined in a volume of space ##V'##. For boson operators satisfying ##[\hat{a}_p, \hat{a}^{\dagger}_q] = \delta_{pq}## show that $$\frac{1}{V}\sum\limits_{pq}e^{i(p \cdot x - q \cdot y)}[\hat{a}_p, \hat{a}^{\dagger}_q] = \delta^{(3)}(x - y)$$, where ##V## is the magnitude of ##V'##. Show the same with fermion operators.
Seen above.
I'm studying Quantum Field Theory for the Gifted Amateur and feel like my math background for it is a bit shaky. This was my attempt at a derivation of the above. I know it's not rigorous, but is it at least conceptually right? I'll only show it for bosons since it's pretty much the same for fermions except the commutator is replaced with the anticommutator.
First note that
$$\frac{1}{V}\sum\limits_{pq}e^{i(p \cdot x - q \cdot y)}[\hat{a}_p, \hat{a}^{\dagger}_q]$$
$$= \frac{1}{V}\sum\limits_{pq}e^{i(p \cdot x - q \cdot y)}\delta_{pq}$$
$$= \frac{1}{V}\sum\limits_p e^{ip \cdot (x - y)}$$
To prove that the sum above is equivalent to ##\delta^{(3)}(x - y)##, we must show 2 things:
1. ##\frac{1}{V}\sum\limits_p e^{ip \cdot (x - y)} = 0## whenever ##x \neq y##
2. $$\int\limits_{V'} d^3x \frac{1}{V}\sum\limits_p e^{ip \cdot (x - y)} = 1$$
The first follows from the periodicity of ##e^{ip \cdot (x - y)}## [EDIT: the periodicity and the fact that for each value, the negative of that value will also appear within one period]. When ##x - y## is nonzero, each ##e^{ip \cdot (x - y)}## term will be cancelled out by some other term ##e^{ip' \cdot (x - y)}##.
For the second,
$$\int\limits_{V'} d^3x \frac{1}{V}\sum\limits_p e^{ip \cdot (x - y)}$$
$$= \frac{1}{V}\sum\limits_p \int\limits_{V'} d^3x e^{ip \cdot (x - y)}$$
Note that due to the same periodicity mentioned above, ##\int\limits_{V'} d^3x e^{ip \cdot (x - y)} = 0## when ##p \neq 0##. So
$$\frac{1}{V}\sum\limits_p \int\limits_{V'} d^3x e^{ip \cdot (x - y)}$$
$$= \frac{1}{V} \int\limits_{V'} d^3x e^{i(0) \cdot (x - y)}$$
$$= \frac{1}{V} \int\limits_{V'} d^3x$$
$$= \frac{1}{V}(V)$$
$$= 1$$
Therefore we have shown that
Does this make sense? Is there anything that should be corrected or made more rigorous? Thanks for your help!
Likes sreerajt and vanhees71
This is just the completeness of the functions ##\exp(\mathrm{i} \vec{p} \cdot \vec{x})## with ##\vec{p} \in \frac{2 \pi}{L} \mathbb{Z}^3## on the square-integrable functions on a cube with periodic boundary conditions. It's proven in many analysis textbooks dealing with Fourier Series.
Thread 'Help with Time-Independent Perturbation Theory "Good" States Proof'
(Disclaimer: this is not a HW question. I am self-studying, and this felt like the type of question I've seen in this forum. If there is somewhere better for me to share this doubt, please let me know and I'll transfer it right away.) I am currently reviewing Chapter 7 of Introduction to QM by Griffiths. I have been stuck for an hour or so trying to understand the last paragraph of this proof (pls check the attached file). It claims that we can express Ψ_{γ}(0) as a linear combination of...
