Showing that a group is non-abelian
  • MHB
  • Thread starter Guest2
  • Tags
    Group
In summary, if G is a group in which $(a \cdot b)^i = a^i \cdot b^i$ for three consecutive integers $i$, then G is abelian.
Guest2
193
$4$. If G is a group in which $(a \cdot b)^i = a^i \cdot b^i$ for three consecutive integers $i$ for all $a, b \in G$, show that $G$ is abelian.
I've done this one. The next one says:
$5$. Show that the conclusion of Problem $4$ does not follow if we assume the relation $(a \cdot b)^i = a^i \cdot b^i$ for just two consecutive integers.
All I can show is that this implies $a^i b = ba^i.$ Any suggestions are appreciated.
What you have written is not true.
Here are two statements that are true:
1) If $G$ is a group such that $(ab)^k = a^kb^k$ for $3$ consecutive integers, $G$ is abelian.
2) If $G$ is a group such that $(ab)^k = a^kb^k$ for $2$ consecutive integers, $G$ may not be abelian.
If #2) is what you meant, then what you are being asked to do is exhibit a counter-example, that is, a non-abelian group such that 2) holds (note that #2) is true of every abelian group, by your previous post).
Thank you, Deveno. I tried to rephrase the question; statement of the problem was in fact that the conclusion of 1) does not follow if we take just two consecutive integers instead. I'm going to have to think about how to exhibit a counterexample to this.
Is this correct? Let $i = k-2, k-1.$ Then by (1) we have have that $(ab)^k = a^kb^k$ implies $G$ is abelian. Also, from my previous post, we have that if $G$ is an abelian group, then for $a, b \in G$ and all integers $n$, $(a \cdot b)^n = a^n \cdot b^n$; and in particular when $n=k.$ Thus $G$ is abelian if and only if $(ab)^k = a^kb^k.$ Thus we have necessary and sufficient condition, so it might not be true for just two consecutive integers.
You can't use 1) in that way, the proof of that requires $3$ consecutive integers, not two.
What you need is to exhibit a non-abelian group $G$ such that $(ab)^i = a^ib^i$ for two consecutive integers $i$, and every $a,b \in G$.
I suggest you pick $G$, and your two values for $i$ carefully. Here is a hint: -1 and 2 would be bad choices.
But I'm using it for three integers. $k-2, k-1$ and $k$.
I take $i=0$ and $i=1$. I get $ab = ab$ which is a counterexample, right?
Unfortunately, you omitted the last $k$ in your prior post-this may have been what you intended, but, alas, my psychic powers of divination are not what they used to be.
Those are good choices for $i$, but you also need some non-abelian group to complete the proof.
$ab = ab$ is an equation, not a proof; to be convincing you need to say something like this:
Let $G$ be a non-abelian group. Then for any two elements $a,b$ (and thus all), we have:
$(ab)^0 = a^0b^0$ because...(insert reason here) and
$(ab)^1 = a^1b^1$ (this might be obvious, but it doesn't hurt to add a little something to the beginning and end)
and $0,1$ are two consecutive integers, therefore...(insert conclusion here).
(Rofl)
Sorry about that.
Thank you very much, this is most helpful!
FAQ: Showing that a group is non-abelian
What does it mean for a group to be non-abelian?
A non-abelian group is a group in which the order of multiplication matters. This means that the result of multiplying two elements in the group will depend on the order in which they are multiplied. In other words, the group is not commutative.
How can you prove that a group is non-abelian?
There are a few different ways to show that a group is non-abelian. One way is to provide a counterexample, where you can find two elements in the group whose product is different depending on the order in which they are multiplied. Another way is to use the definition of an abelian group and show that it does not hold for the given group.
Can a group be both abelian and non-abelian?
No, a group cannot be both abelian and non-abelian. This would be a contradiction, as the definition of an abelian group is that it is commutative, while a non-abelian group is not commutative. A group can only have one of these properties.
Are all symmetric groups non-abelian?
No, not all symmetric groups are non-abelian. Symmetric groups are groups of permutations, and some permutations are commutative while others are not. Therefore, some symmetric groups may be abelian while others may be non-abelian.
Can a finite group be non-abelian?
Yes, a finite group can be non-abelian. The order or size of a group does not determine whether it is abelian or non-abelian. It is possible for both finite and infinite groups to be either abelian or non-abelian.
