Showing that $A$ is an Ideal of $\mathbb{Q}[x]$ and Expressing it as $<f(x)>$
  • MHB
  • Thread starter mathmari
In summary, the conversation discussed how to show that the set A, consisting of polynomials with a root at i, is an ideal of the ring $\mathbb{Q}[x]$ and how to express it in the form $<f(x)>$. The conversation also touched on the fact that $\mathbb{Q}[x]$ is a principal ideal domain and the use of the Euclidean function to prove this. It was also mentioned that $i$ is a root of $x^2 + 1$ and that this can be used to show that $\langle x^2 + 1\rangle \subseteq A$. Finally, it was established that both left and right ideals are equivalent to two-sided ideals in a commut
mathmari
MHB
5,049
Hey! :eek:
I have to show that the set $$A=\{f(x) \in \mathbb{Q}[x], f(i)=0\}$$ is an ideal of the ring $\mathbb{Q}[x]$ and I have to express it in the form $<f(x)>$.
I have done the following:
To show that $A=\{f(x) \in \mathbb{Q}[x], f(i)=0\}$ is an ideal of the ring $\mathbb{Q}[x]$, we have to show that:
1. $\forall f(x) \in A, g(x) \in \mathbb{Q}[x], g(x) \cdot f(x) \in A $
2. $\forall f(x) \in A, g(x) \in \mathbb{Q}[x], f(x) \cdot g(x) \in A $
3. $\forall h(x), f(x) \in A, h(x)-f(x) \in A $1. $f(x) \in A$, so $f(x) \in \mathbb{Q}[x]$ and $f(i)=0 $
$g(x) \in \mathbb{Q}[x] $
Since $f(x) \in \mathbb{Q}[x]$ and $g(x) \in \mathbb{Q}[x]$ and since $\mathbb{Q}$ is a ring, it implies that $g(x) \cdot f(x) \in \mathbb{Q}[x]$.
$g(i) \cdot f(i)=g(i) \cdot 0=0 $
Therefore, $g(x) \cdot f(x) \in A$. 2. $f(x) \in A$, so $f(x) \in \mathbb{Q}[x]$ and $f(i)=0 $
Since $g(x) \in \mathbb{Q}[x]$ and $f(x) \in \mathbb{Q}[x]$ and since $\mathbb{Q}$ is a ring, it implies that $f(x) \cdot g(x) \in \mathbb{Q}[x] $.
$f(i) \cdot g(i)=0 \cdot g(i)=0 $
Therefore, $f(x) \cdot g(x) \in A$. 3. $f(x) \in A$, so $f(x) \in \mathbb{Q}[x]$ and $f(i)=0 $
$h(x) \in A$, so $h(x) \in \mathbb{Q}[x]$ and $h(i)=0 $
Since $f(x) \in \mathbb{Q}[x]$ and $h(x) \in \mathbb{Q}[x]$ and since $\mathbb{Q}$ is a ring, it implies that $h(x) - f(x) \in \mathbb{Q}[x]$.
$h(i) -f(i)=0-0=0 $
Therefore, $h(x) -f(x) \in A$. Therefore, $A$ is an ideal.
Is this correct?? (Wondering)How can I write the ideal $A$ in the form $<f(x)>$?? (Wondering)
What you've done so far is OK.
(2) is actually unnecessary, $\Bbb Q[x]$ is a commutative ring, so (1) is all you need.
Personally, I would use another letter besides "$f$" to indicate the generator of $A$, since you are taking $f(x)$ to be a "general" polynomial, and for the generator of $A$ you want a "specific" one.
For of all, you need to know/show that $\Bbb Q[x]$ is a PRINCIPAL IDEAL DOMAIN. The easiest way to do this is to use the fact that any Euclidean domain is a principal ideal domain.
The Euclidean "$d$" function for $\Bbb Q[x]$ is the degree of a polynomial. This is because, for ANY two non-zero polynomials:
$f(x),g(x) \in \Bbb Q[x]$, we can write:
$f(x) = g(x)q(x) + r(x)$ for UNIQUE polynomials $q(x),r(x)$ with $r(x) = 0$ (the 0-polynomial, not the number) or $\text{deg}(r(x)) < \text{deg}(g(x))$.
It is unclear what you mean by "$i$". If you mean a root of $x^2 + 1$, then it is clear that $\langle x^2 + 1\rangle \subseteq A$.
On the other hand, suppose that:
$p(x) \in A$. Write:
$p(x) = (x^2+1)q(x) + r(x)$.
Since $p(i) = 0$ (because it's in $A$), we have:
$0 = 0q(i) + r(i) = r(i)$.
If $r(x) \neq 0$, then $r(x)$ has degree 1, so $r(x) = ax + b$ for some rational numbers $a,b$, with $a \neq 0$.
Since $r(i) = 0$, it must be $i$ is a root of $r(x) = ax + b$.
Thus $ai + b = 0 \implies i = -\dfrac{b}{a}$. But this is absurd, since:
$\left(-\dfrac{b}{a}\right)^2 + 1 = \dfrac{b^2}{a^2} + 1 = \dfrac{b^2 + a^2}{a^2} > 0$ (since $a \neq 0$ -this uses the ORDER properties of $\Bbb Q$).
Our only other option is that $r(x) = 0$, in which case $p(x) = (x^2 + 1)q(x) \in \langle x^2 + 1\rangle$.
This shows $A \subseteq \langle x^2 + 1\rangle$, so the two are equal.
For the first part, do you mean that I don`t have to write (2) at all, or do I have to include it into (1)??
(2) follows from (1) by commutativity.
In a commutative ring: left-ideal = right-ideal = two-sided ideal.
$\Bbb Q[x]$ is a commutative ring, for all polynomials $f(x),g(x) \in \Bbb Q[x]$:
$f(x)g(x) = g(x)f(x)$.
I understand! (Happy) Thank you very much! (Smile)
FAQ: Showing that $A$ is an Ideal of $\mathbb{Q}[x]$ and Expressing it as $<f(x)>$
How do you show that a set is an ideal of $\mathbb{Q}[x]$?
To show that a set $A$ is an ideal of $\mathbb{Q}[x]$, you must prove that it satisfies the two defining properties of an ideal: closure under addition and closure under multiplication by elements in $\mathbb{Q}[x]$. This means that for any $f(x), g(x) \in A$ and $h(x) \in \mathbb{Q}[x]$, $f(x) + g(x) \in A$ and $f(x)h(x) \in A$.
What is the significance of expressing an ideal as $$?
Expressing an ideal $A$ as $$ means that the ideal is generated by the polynomial $f(x)$. This means that every element of $A$ can be written as a multiple of $f(x)$, and conversely, any multiple of $f(x)$ is contained in $A$. This notation allows us to easily understand the structure and properties of the ideal $A$.
How do you determine the generator $f(x)$ of an ideal $A$?
To determine the generator $f(x)$ of an ideal $A$, you must first find the set of all elements of $A$. Then, find the polynomial in this set with the smallest degree. This polynomial will be the generator $f(x)$ of the ideal $A$.
Can an ideal have multiple generators?
Yes, an ideal can have multiple generators. In fact, it is possible for an ideal to have infinitely many generators. However, there is always a "minimal" set of generators for an ideal, meaning that any other set of generators can be expressed as a combination of these minimal generators.
Is every subset of $\mathbb{Q}[x]$ an ideal?
No, not every subset of $\mathbb{Q}[x]$ is an ideal. To be an ideal, a subset must satisfy the two defining properties of an ideal: closure under addition and closure under multiplication by elements in $\mathbb{Q}[x]$. If a subset does not satisfy these properties, it is not an ideal.
