Showing that B is invertible if A = BAB, where A is invertib
  • Thread starter Mr Davis 97
In summary: It's not generally true in a ring that a left inverse implies a right inverse. So, you need more than the ring...In summary, the conversation discusses the concept of finding an inverse of a matrix, specifically in the case where A and B are square matrices and A is invertible. It is shown that if A = BAB, then B is also invertible. The conversation also explores the relationship between left and right inverses and how the determinant is related to the existence of an inverse. It is concluded that for general m x n matrices, the concept of inverses may not be defined.
Mr Davis 97
1,462
44
Let A and B be square matrices. Suppose that A is invertible and A = BAB. Show that B is invertible.
First, since BAB = A, and A is invertible, this means that B(ABA-1) = I. However, to show that B is invertible, I also need to show that (ABA-1)B = I, but I don't see how to do this...
With the same method you can construct a (possibly different) left inverse C of B.
Then you have CB = 1 = BD. (In your case you already have D = ABA-1.)
Now show that in general C=D has to hold.
Well ABA-1 = A-1BA only if A = A-1, right? But we aren't given that in the problem.
And it is not necessary. (Probably it isn't true either, but I haven't thought about a counterexample.)
I read your question as you have found C=A-1BA.
So forget now the A and prove: CB=BD implies C=D, which is useful to know in other cases, too.
Edit: I forgot to repeat that CB=BD=1 which is important here.
I'm not seeing how to do it. Since we aren't given that C, B, or D have an inverse, it doesn't seem possible to manipulate the equation CB = BD to get C = D,
You have found a left inverse C of B and a right inverse D of B. (C=A-1BA and D=ABA-1)
Thus you know CB=1=BD. What is CBD?
To quote for another of your threads:
Ray Vickson said:
There is a standard theorem which states that if a square matrix A has a right (left) inverse B, then it also has a left (right) inverse, and that is equal to B as well. You should expand your understanding by trying to prove that theorem.
There's also that useful little concept called the determinant!
So are you saying that to find an inverse for an nxn matrix I only need to show that AC = I, then automatically CA = I too?
You should be able to prove that easily enough. And, again, I would like to mention the d-word: "determinant".
Well, using determinants, on ##AC = CA##, we get that ##det(A) det(C) = det(C) det(A)##, which is a true equation, but I don't see how we can then go back to say that AC = CA as result
The determinant is related to the existence of an inverse.
Well we know that ##det(A) det(C) = det(C) det(A) = 1##, so both AC and CA have an inverse. Does this imply that A has an inverse and that inverse is C?
If ##det(A) det(C) = 1##, what does that tell you about ##det(A)## and ##det(C)##?
That neither is zero, and thus they're both invertible. Thus, C is the inverse of A, and A is the inverse of C, since CA = I. Is that right?
Also, is this only true for n x n matrices because of general m x n matrices we can't take determinants?
You might like to tidy it up by saying that if ##AC = I## then ##det(C) \ne 0## hence ##C^{-1}## exists and:
##ACC^{-1} = IC^{-1}##, hence ##A = C^{-1}##
For general m x n matrices, ##AC## and ##CA## are generally not defined.
Just out of curiosity, is there any simple way to prove it without determinants?
It's not generally true in a ring that a left inverse implies a right inverse. So, you need more than the ring axioms.
If you already have a left inverse ##CB = I## and a right inverse ##BD = I## as in your case, then all you need is associativity to prove they are equal: ## C = C \cdot I = C\cdot (BD) = (CB)\cdot D = I\cdot D = D##
And to not confuse you with what @PeroK has said: You cannot automatically assume that the existence of a one-sided inverse implies one from the other side. However, you've proven the existence of both inverses to ##B## in posts #1, #3. Strictly speaking, that's all you needed to do. The equality of both hasn't been required. But as you can see, it's easy to do in this case.
Likes Mr Davis 97 and PeroK
Ah, okay, thanks for clearing that all up. So just to be clear, if I have found that AC= I, then this does not guarantee that A has an inverse. I need to show also that there exists a D such that DA = I, and if this is the case, it must be so that D = C.
Yes.
But "this does not guarantee that A has an inverse" only in the sense of a two-sided inverse. With "AC=I" it has a right inverse.
Let's consider functions ##f : \mathbb{N} \rightarrow \mathbb{N}##.
Then for ##f_1(x) := x+1## and ##f_2(x) := \begin{cases} x-1 & \text{ for } x \geq 2 \\ 1 & \text{ for } x=1 \end{cases} ##
we get ##f_2 \circ f_1 = id_\mathbb{N}## and ##f_1 \circ f_2 \neq id_\mathbb{N}##. This is an example where ##f_2## has a right inverse but no left inverse.
Perhaps to summarise:
1) In this particular problem, you are dealing with square matrices and given that ##A = BAB## and ##A## is invertible.
The simplest way to solve this is to consider determinants, as you can see immediately that ##B## must be invertible.
As has been shown, however, you only need the ring axioms to show that ##B## is invertible in this case.
2) There was then a related question:
For square matrices if ##AB = I## then ##A## and ##B## are invertible and, of course, ##A = B^{-1}##.
Again, considering determinants shows this immediately.
But, if ##A## & ##B## are elements of an arbitrary ring, then it does not follow that ##BA = I##. As shown by the above counterexample.
3) The moral is that matrices have specific properties, in particular in terms of inverses, beyond those that all rings have. And these properties are often encapsulated by the equivalence of having an inverse with a having non-zero determinant.
Likes Mr Davis 97
fresh_42 said:
Yes.
Wait, so if I have ##AC = I##, then this does not guarantee that A has a left inverse, right? However, if I take the determinant, we see that ##det(A) det(B) = 1##,so A and B both must be invertible. But I thought that ##AC = I## doesn't guarantee a left-inverse?
PeroK said:
[Emphasis by me.] "3) The moral is that matrices have specific properties, in particular in terms of inverses, beyond those that all rings have. And these properties are often encapsulated by the equivalence of having an inverse with a having non-zero determinant."
Beside this, how did you find ##B\, ##? ##AC=I## gives you ##\det(A) \det(C) = 1##, so both, ##A## and ##C## are invertible and ##C## is a right inverse of ##A## which is a left inverse of ##C##. How come ##B## as a left inverse of ##A## into play without any additional conditions or deviations? Will ##B=C## always do the job? How can we guarantee that ##\det (C) \det(A) = 1## implies ##CA = I\,##? And how, that ##\det (C) \det(A) = 1## even holds? Where is it stated, that our matrix elements have a commutative multiplication?
I have no good counterexamples at hand, for in most common cases, a right inverse matrix is also the left inverse matrix, and as shown above, together with associativity they are the same then. I know of non associative examples, but they also lack of the classical unity matrix.
Nevertheless, one has to be careful about what is explicitly given and what is somehow automatically assumed for the reasons: "How can it be not the case?" or "It has always been so!" Both are no valuable mathematical arguments. The fact, that counterexamples might be difficult to find, does not mean there are none.
Related to Showing that B is invertible if A = BAB, where A is invertib
1. What does it mean for a matrix to be invertible?
A matrix is invertible if it has an inverse matrix, meaning that the original matrix can be multiplied by its inverse to produce the identity matrix. In other words, the inverse of a matrix "undoes" the effects of the original matrix.
2. How can we prove that B is invertible if A = BAB?
To prove that B is invertible if A = BAB, we can use the fact that if A is invertible, then A = BAB if and only if BA = I. So, we can multiply both sides by A^-1 to get B = A^-1I = A^-1, which shows that B is invertible.
3. Can you provide an example of a matrix that satisfies A = BAB and show how to find its inverse?
One example of a matrix that satisfies A = BAB is: A = [2 4; 6 8] and B = [1 3; 5 7]. To find the inverse of B, we can use the formula for a 2x2 matrix: B^-1 = (1/ad-bc) [d -b; -c a]. Plugging in the values from B, we get B^-1 = (-1/2) [-7 3; 5 -1].
4. Can A be invertible if B is not invertible?
Yes, it is possible for A to be invertible even if B is not invertible. This can happen if B is a singular matrix (meaning it does not have an inverse) but A has an inverse that can "cancel out" the effects of B.
5. Are there any other methods for proving the invertibility of B in this scenario?
Yes, there are other methods for proving the invertibility of B in this scenario. One approach is to use the determinant of a matrix - if the determinant of B is non-zero, then B is invertible. Another method is to use the rank of a matrix - if the rank of B is equal to its number of columns, then B is invertible.
11K
