Showing that preimage of a subgroup is a subgroup
  • Thread starter Mr Davis 97
  • Tags
    Subgroup
In summary, the preimage of a subgroup under a group homomorphism is also a subgroup of the original group. This is proven by showing that the preimage is nonempty and closed under multiplication and inverses, thus satisfying the definition of a subgroup.
Mr Davis 97
1,462
44
Prove that if ##f:G\to H## is a group homomorphism and ##K\leq H## then the preimage of ##K##, defined as ##f^{-1}(K)=\{g\in G | f(g)\in K\}##, is a subgroup of ##G##.
1) Note that ##f^{-1}(K)## is nonempty, since ##f(e_G) = e_H## and ##e_H \in K##. So ##e_G \in f^{-1}(K)##.
2) Let ##x,y \in f^{-1}(K)##. So ##f(x),f(y) \in K## by the definition of the preimage of K. Then ##f(xy^{-1}) = f(x)f(y^{-1}) = f(x)f(y)^{-1} \in K## because ##f(x),f(y) \in K## and ##K## is closed under multiplication and inverses. Hence ##xy^{-1} \in f^{-1}(K)##.
We conclude that ##f^{-1}(K) \le G##.
Yes. Nothing to add this time. :smile:
Likes Mr Davis 97
Related to Showing that preimage of a subgroup is a subgroup
What is a preimage of a subgroup?
A preimage of a subgroup is the set of all elements in the original group that map to the subgroup under a given homomorphism.
Why is it important to show that the preimage of a subgroup is a subgroup?
It is important to show that the preimage of a subgroup is a subgroup because it helps us understand the structure of the original group and how it is related to the subgroup. It also allows us to use properties of subgroups to make conclusions about the original group.
How do you prove that the preimage of a subgroup is a subgroup?
To prove that the preimage of a subgroup is a subgroup, we need to show that it satisfies the three properties of a subgroup: closure, identity, and inverse. This can be done by showing that the original group elements that map to the subgroup also satisfy these properties.
Can the preimage of a subgroup be a proper subgroup of the original group?
Yes, the preimage of a subgroup can be a proper subgroup of the original group. This means that not all elements in the original group map to the subgroup, and there may be elements in the preimage that do not have a corresponding element in the subgroup.
What happens if the homomorphism is not injective?
If the homomorphism is not injective, it means that there are elements in the original group that map to the same element in the subgroup. This can result in the preimage of the subgroup being a larger subgroup than the original subgroup, as more elements in the original group are mapping to the same element in the subgroup.
