MHB Showing that Q(sqrt(p)) is in Q adjoined the pth root of unity
  • Thread starter Thread starter oblixps
    Root Unity
The discussion revolves around proving that Q(sqrt(p*)) is contained in Q(zeta_p), where p* is defined based on the congruence of p modulo 4. The key insight involves using the Vandermonde matrix formed by the pth roots of unity, which leads to the conclusion that the determinant of this matrix can be either real or purely imaginary depending on the parity of (p-1)/2. If (p-1)/2 is even, it shows that sqrt(p) is in Q(zeta), while if it is odd, it demonstrates that sqrt(-p) is in Q(zeta). This establishes the desired inclusion for both cases of p.
oblixps
i am having trouble showing that \mathbb{Q}(\sqrt{p*}) \subset \mathbb{Q}(\zeta_{p}) where p* = (-1)^{\frac{p-1}{2}}p. in other words, if p = 1 (mod 4) then p* = p and if p = 3 (mod 4) then p* = -p. i encountered this in the context of galois theory and i have no idea how to start. it seems that i need to know what \zeta_{p} looks like before i decide if \sqrt{p*} \in \mathbb{Q}(\zeta_{p}) but for arbitrary p that is hard to figure out. i also can't figure out why we have the 1 mod 4 and 3 mod 4. can someone give me some hints on this question?
Mathematics news on Phys.org
Sorry for the long delay in responding – I didn't see this thread when it was first posted.
I believe that the key to this problem is to use the Vandermonde matrix formed by the $p$th roots of unity. If $\zeta = e^{2\pi i/p}$, let $V_p$ be the $p\times p$ matrix whose $(i,j)$-element is $\zeta^{\,ij}$ for $0\leqslant i,j\leqslant p-1$ (notice that the rows and columns are labelled from 0 to $p-1$ rather than from 1 to $p$). The first thing to check is that $V_pV_p^* = pI_p$, where the star denotes the hermitian transpose and $I_p$ is the $p\times p$ identity matrix. It follows that $|\det(V_p)| = p^{p/2}.$
Next, the matrix $V_p$ is unchanged if for $1\leqslant i\leqslant (p-1)/2$ we interchange row $i$ with row $p-i$ and then take the complex conjugate of each element of the resulting matrix. Interchanging two rows of a matrix changes the sign of its determinant, so if $(p-1)/2$ is even then the number of sign changes is even and so $\det(V_p) = \overline{\det(V_p)}$ (the bar denoting the complex conjugate). Therefore $\det(V_p)$ is real and it follows from the previous paragraph that $p^{-(p-1)/2}\det(V_p) = \pm\sqrt p$. But the left side of that equation is in $\mathbb{Q}(\zeta)$, so $\sqrt p \in\mathbb{Q}(\zeta)$ and hence $\mathbb{Q}(\sqrt p)\subseteq \mathbb{Q}(\zeta)$.
If $(p-1)/2$ is odd, then a similar argument shows that $\det(V_p)$ is purely imaginary and therefore $p^{-(p-1)/2}\det(V_p) = \pm\sqrt{-p}$, from which $\mathbb{Q}(\sqrt {-p})\subseteq \mathbb{Q}(\zeta)$.
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
