Showing That The Infinite Series 1/n is less than 2
In summary, the homework statement is trying to solve a problem that has the student struggling to find an answer and the solution to the problem is to use a power series expansion.
jsewell94
23
Consider the series:
[itex]\sum\frac{1}{n!}[/itex], where n begins at one and grows infinitely larger (Sorry, I'm still a bit new to the equation editor on here :) )
1) Use the ratio test to prove that this series is convergent.
2) Use the comparison test to show that S < 2
3) Write down the exact value of S.
2. The attempt at a solution
The first part of this problem was rather simple.
However, parts 2 and 3 have me completely stumped. I have tried comparing [itex]\frac{1}{n!}[/itex] to [itex]\frac{1}{n^2}[/itex], but when n = 4, [itex]\frac{1}{n!}[/itex] becomes smaller than [itex]\frac{1}{n^2}[/itex]. Which leads me to believe that this would be true for any series of the form [itex]\frac{1}{n^p}[/itex].
I have also considered using a geometric series, but, again, I can't think of any that would remain less than [itex]\frac{1}{n!}[/itex]...
So, what exactly do I compare it too? You don't have to outright give me the answer, but a nudge in the right direction would be nice. And I figure that once I get part 2, part 3 SHOULD fall into place.
Thanks guys!
well it is just e-1
I am aware that the answer is e-1, but I need to know how to get that. :)
For the comparison part here's a hint: 1/(1*2*3)<1/(1*2*2).
Oh, wow...I was totally making this way more difficult than it needed to be. Thanks!
So I managed to prove that the sum is less than 2. Now how do I go about finding the exact value of the sum?
For that one I think you need to use the power series expansion of e^x.
FAQ: Showing That The Infinite Series 1/n is less than 2
What is an infinite series?
An infinite series is a sum of an infinite number of terms. It can be written in the form a1 + a2 + a3 + ..., where an is the nth term of the series.
What is the infinite series 1/n?
The infinite series 1/n is a specific type of infinite series where each term is equal to 1 divided by n, where n is a positive integer. So the series can be written as 1/1 + 1/2 + 1/3 + 1/4 + ...
How can we show that the infinite series 1/n is less than 2?
To show that the infinite series 1/n is less than 2, we can use a mathematical proof. One way to do this is by using the comparison test, which states that if an infinite series an is smaller than another infinite series bn and bn converges, then an also converges. In this case, we can compare the series 1/n to the series 1/2n, which is known to converge to 2. Since 1/n is smaller than 1/2n, it must also converge to a value less than 2.
Why is it important to show that the infinite series 1/n is less than 2?
Showing that the infinite series 1/n is less than 2 is important because it helps us understand the behavior of the series and its convergence. It also has applications in various branches of mathematics, such as calculus and number theory.
What are some real-world examples of the infinite series 1/n?
The infinite series 1/n can be found in various real-world situations, such as calculating the total resistance of an infinite series of resistors in a circuit, calculating the total distance traveled by a person walking at decreasing speeds, and estimating the value of pi using the Gregory-Leibniz series.
