Showing the Other Root of $4x^2+2x-1= 0$ Given $\alpha$
  • MHB
  • Thread starter kaliprasad
  • Tags
    Root
In summary, the conversation discusses finding the other root of a quadratic equation when one root is given. It is shown that the other root is equal to $4\alpha^3-3\alpha$, where $\alpha$ is the given root. Three individuals, markfl, anemone, and greg, provide their solutions to this problem.
kaliprasad
MHB
1,335
If one root of $4x^2+2x-1= 0 $ be $\alpha$ then show that other root is $4\alpha^3-3\alpha$
Mathematics news on Phys.org
my solution:
for $\alpha $ is a root ,we must have $4\alpha^2+2\alpha -1=0----(1)$
let $\alpha +4\alpha^3-3\alpha=x----(2)$
and $\alpha \times (4\alpha^3-3\alpha)=4\alpha^4-3\alpha^2=y----(3)$
$(2)\times \alpha \rightarrow 4\alpha^4-2\alpha^2=x\alpha----(4)$
$(4)-(3):\alpha^2=x\alpha -y \rightarrow 4\alpha^2-4x\alpha+4y=0----(5)$
compare$(1)\,\, and\,\, (5)$,we have $x=\dfrac{-1}{2},y=\dfrac {-1}{4}$
and the proof is finished
Albert said:
my solution:
this is not proof as you are asuming the result and based on it you prove it you have assumed that (1) is the only equation satisfied by $\alpha$
I prove $\alpha \,\, and \,\,4\alpha^3-3\alpha$ satisfy Vieta's formulas
if $\alpha $ is a root ,and $4\alpha^3-3\alpha$ is another root ,then their sum and product must satisfy Vieta's formulas
and more $4x^2+2x-1=0 $ has exactly only two roots
My solution:
Let:
\(\displaystyle \alpha=\frac{-1\pm\sqrt{5}}{4}\)
Then:
\(\displaystyle 4\alpha^3-3\alpha=4\left(\frac{-1\pm\sqrt{5}}{4}\right)^3-3\left(\frac{-1\pm\sqrt{5}}{4}\right)=\frac{-16\pm8\sqrt{5}+12\mp12\sqrt{5}}{16}=\frac{-1\mp\sqrt{5}}{4}\)
Thus, when $\alpha$ is one root, $4\alpha^3-3\alpha$ is the other.
MarkFL said:
My solution:
Let:
Then:
\(\displaystyle 4\alpha^3-3\alpha=4\left(\frac{-1\pm\sqrt{5}}{4}\right)^3-3\left(\frac{-1\pm\sqrt{5}}{4}\right)=\frac{-16\pm8\sqrt{5}+12\mp12\sqrt{5}}{16}=\frac{-1\mp\sqrt{5}}{5}--(*)\)
a typo :
(*)should be: $4\alpha^3-3\alpha
=\dfrac{-1\mp\sqrt{5}}{4}$
Albert said:
a typo :
Fixed...and I hid the information in your post regarding a solution using the spoiler tags as a courtesy to the community. :)
My solution:
\(\displaystyle x=\frac{-1+\sqrt{5}}{4}\) is a solution for $4x^2+2x-1= 0$ and it's also known to be $\cos 72^\circ$(sum 36+36). The other solution for $4x^2+2x-1= 0$ is \(\displaystyle x=-\left(\frac{1+\sqrt{5}}{4}\right)\) and it's known to be $-\cos 36^\circ=\cos (180^\circ+36^\circ)=\cos 3(72^\circ)$.
We therefore can conclude that if one of the roots for $4x^2+2x-1= 0$ is $\alpha$, which is $\cos 72^\circ$, the other root, $\cos 3(72^\circ)$ will be $4\alpha^3-3\alpha$, which abides by the triple angle formula for cosine function: $\cos 3\alpha=4\cos^3 \alpha -3\cos\alpha$
I know that $\cos(36^\circ)=\dfrac{\sqrt5+1}{4}$. By the quadratic relation, the two roots of the given quadratic are
$$\dfrac{\sqrt5-1}{4}$$ and $$-\dfrac{\sqrt5+1}{4}$$
so we have
$$\cos(36^\circ)-\dfrac{\sqrt5+1}{2}=-\dfrac{\sqrt5+1}{4}$$
$$\cos(36^\circ)-2\cos(36^\circ)=-\dfrac{\sqrt5+1}{4}$$
$$-\cos(36^\circ)=\cos(216^\circ)=-\dfrac{\sqrt5+1}{4}$$
thus the other root is $\cos(216^\circ)$.
Now,
$$4\cos^3(x)-3\cos(x)=\cos(3x)$$
so, if $\cos(72)=\dfrac{\sqrt5-1}{4}$, we are done.
$$\cos(72^\circ)=2\cos^2(36^\circ)-1=2\left(\dfrac{\sqrt5+1}{4}\right)^2-1=\dfrac{\sqrt5-1}{4}$$
as required.
Thanks to anemone for inspiration.
three good answers markfl, anemone and greg and here is my answer.
We have $4\alpha^2+2\alpha-1= 0\cdots(1) $
We need to prove
$4(4\alpha^3-3\alpha)^2+2(4\alpha^3-3\alpha)-1= 0 $
we have $4\alpha^2+2\alpha-1= 0$
Hence $4\alpha^3+2\alpha^2-\alpha= 0$
$4\alpha^3 = -2\alpha^2 + \alpha$
or $4\alpha^3 -3\alpha = - 2\alpha^2 - 2 \alpha= - \frac{1}{2}( 4\alpha^2 + 4\alpha)$
$= - \frac{1}{2}( 1 - 2\alpha + 4\alpha)= - \frac{1}{2}( 1 + 2\alpha) \dots(2)$
Hence $4(4\alpha^3-3\alpha)^2+2(4\alpha^3-3\alpha)-1= 0 $
= $4(\frac{1}{2}( 1 + 2\alpha))^2- 2 (\frac{1}{2}( 1 + 2\alpha)-1$ using (2)
= $( 1 + 2\alpha))^2- ( 1 + 2\alpha)-1$
= $1 + 4 \alpha + 4\alpha ^2 - 1 -2 \alpha -1$
= $4\alpha ^2 + 2 \alpha -1= 0$ from (1)
FAQ: Showing the Other Root of $4x^2+2x-1= 0$ Given $\alpha$
What is the other root of $4x^2+2x-1=0$ given $\alpha$?
The other root of $4x^2+2x-1=0$ given $\alpha$ can be found by using the quadratic formula. The formula is $x=\frac{-b\pm\sqrt{b^2-4ac}}{2a}$, where $a=4$, $b=2$, and $c=-1$. Plugging in the values, we get $x=\frac{-2\pm\sqrt{2^2-4(4)(-1)}}{2(4)}$, which simplifies to $x=\frac{-2\pm\sqrt{24}}{8}$. Therefore, the other root is $\frac{-2+\sqrt{24}}{8}$ or $\frac{-2-\sqrt{24}}{8}$.
How do you find the other root of $4x^2+2x-1=0$ given $\alpha$?
The other root of $4x^2+2x-1=0$ given $\alpha$ can be found by using the quadratic formula or by factoring the equation. In this case, the equation can be factored as $(2x+1)(2x-1)=0$, which means that the roots are $x=-\frac{1}{2}$ and $x=\frac{1}{2}$. Therefore, the other root is $x=\frac{1}{2}$.
Can the other root of $4x^2+2x-1=0$ given $\alpha$ be a complex number?
Yes, the other root of $4x^2+2x-1=0$ given $\alpha$ can be a complex number. In fact, in this equation, the other root is a complex number since $\sqrt{24}$ is an imaginary number. The other root is $\frac{-2+\sqrt{24}}{8}=\frac{-2+2\sqrt{6}i}{8}=\frac{-1+\sqrt{6}i}{4}$ or $\frac{-2-\sqrt{24}}{8}=\frac{-2-2\sqrt{6}i}{8}=\frac{-1-\sqrt{6}i}{4}$.
Is the other root of $4x^2+2x-1=0$ given $\alpha$ always different from $\alpha$?
No, the other root of $4x^2+2x-1=0$ given $\alpha$ may or may not be different from $\alpha$. It depends on the values of $a$, $b$, and $c$ in the quadratic equation. In this case, the other root is different from $\alpha$ since $x=\alpha$ is not a solution to the equation. However, if the values of $a$, $b$, and $c$ are different, then the other root may be the same as $\alpha$.
Why is it important to find the other root of $4x^2+2x-1=0$ given $\alpha$?
It is important to find the other root of $4x^2+2x-1=0$ given $\alpha$ because it gives us the complete solution to the quadratic equation. By finding both roots, we can verify that the equation has two solutions and we can also use the roots to graph the equation and find the x-intercepts. Additionally, knowing both roots can help us determine the behavior of the graph, such as whether it opens up or down, and whether it has a minimum or maximum value.
