hellocello
- 9
1. The problem:
A 5-kg block is moved from the ground to a height of 1 m via two different routes, vertically
and along an inclined plane with angle of 30° to the horizontal. How much work is done on
the block against gravity in each case?
W=Fcosθd where θ is between the displacement and force, Fg=mg
I realize the answer is that the work done is the same because it is path independent, but I don't understand why I can't show this in my calculations. Any help is greatly appreciated.
For the vertical path, I did
W=Fcosθd
W=mgcos(0)(1m)
W=(5kg)(9.8m/s^2)(1)(1m) ≈ 50 J
For the inclined path I did
W=Fcosθd where the force required to move the object along the plane is =mgsin(30°) and the angle between the displacement and force would now be 60° so
W=mgsin(30°)cos(60°)(1m) ≈12.5 J
Where I get only a fourth of the work I found above. What am I doing wrong?
(I assumed there was no friction because the question only asks about the work done against gravity)
W=Fcosθd
W=mgcos(0)(1m)
