Shrinking a polygon -- calculation logic
RobinCris
I am working on a project of modeling building for greenBuilding.
for the simulation, I need to put the vertices for the outside of the flat external wall, the the centeral of the wall between flats.
For this, I am doing great and I also calculated the area.
But I also need the NET floor area by reducing the walls thickness.
Not all the wall have the same thickness but I do know this
1. the Gross area
2. the thickness of each wall
3. the length of each wall
4. the vertices for the bigger polygon
How can I substract the walls from the Gross to get the NET floor area
Mathematics news on Phys.org
How about just making new walls with the external vertices where the inside vertices of the first walls are? That should give you the internal area that you want, no?
Do you have any plots of your work to help us visualize what you are doing?
Likes Lnewqban
  • Calcuate the area for each wall assuming it is a simple rectangle (i.e. length x thickness) and deduct it from the gross external area.
  • Add back the areas you have counted twice where walls 'overlap' in the corners (if you have any internal corners draw a sketch and think about how they are different from external corners). If you have any corners that are not right angles, again think about these carefully with a sketch.
Note that what you are looking for is usually called the gross internal area (GIA), not the net floor area.
  • Electrical Engineering
  • Materials and Chemical Engineering
