Can Objects Shrink or Enlarge According to Physics?
  • Thread starter bassplayer142
In summary: Heating (cooling) will cause objects to expand (shrink). The coefficients are small though, something like a factor of 10^-6 per degree C or something of that order. Polymers can get up to maybe 10^-4 per degree C?The obvious upper limit is melting the object before it gets big enough!
bassplayer142
432
I know this sounds like a cheesy movie. But what laws of physics or equations denies this from occurring? Or is it theoretically possible?
Hmm... maybe between Casimir plates or some such, the vacuum energy density can be altered so as to affect (reduce or increase) the screening of electric charges. Basically, the size of objects seems to be determined by the (apparent) charge of the electron; if the electromagnetic interaction were stronger then the scale of atoms (and hence matter) should be smaller. How's that for sci-fi material?
Well if you wanted to enlarge something in some proportionality to your original object you'd need to create some amount of mass from pure energy E=mc^2. You have to find out how to do this first.
If you can get the mass elsewhere then you might as well simply conventionally build the desired object?
As for shrinking something macroscopic... kaboom! I can't see it working on a macroscopic level.
So to answer your question as for enlarging/shrinking macroscopic objects by some sort of 'diabolical ray beam device' it would be the energy costs/massive explosions.
What if you changed the electron configuration surrounding an atom? Since 99% of the atom is empty space. If you closed that gap everything should come together closer right?
If you're referring to something like 'Them' or 'The Attack of the Fifty-Foot Woman', the basic barrier is the 'square-cube rule'. By whatever means you manage to fill in the gaps to maintain a solid structure, that rule holds. As someone enlarges, the mass increases as the cube of the expansion; the structural strength of the bones and connective tissues increases as the square. At some point, the thing is simply not capable of supporting its own weight.
The Lorentz transformations may be useful here in short:
[tex]l = l' \sqrt{1 - \frac{u^2}{c^2} [/tex]
[tex] u = [/tex] velocity
[tex]c = [/tex]speed of light
[tex]l' = [/tex]length in inertial frame
[tex]l = [/tex]length in reference frame
thus an object moving at all will "contract" by an amount, according to relativity:
[tex]\sqrt{1 - \frac{u^2}{c^2} [/tex]
But perhaps I've misunderstood the question?
Claude.
FAQ: Can Objects Shrink or Enlarge According to Physics?
1. How can I shrink or enlarge objects?
To shrink or enlarge objects, you can use various methods such as changing the temperature, pressure, or applying a force. For example, heating an object can cause it to expand, while cooling it can cause it to shrink. Applying pressure to an object can also change its size, depending on the material and its properties.
2. Can I shrink or enlarge any object?
No, not all objects can be easily shrunk or enlarged. Some materials, such as metals, can be easily manipulated through heating and cooling, while others, like plastics, may not respond well to these methods. The size and shape of the object may also affect its ability to be shrunk or enlarged.
3. Is it possible to shrink or enlarge objects indefinitely?
Technically, yes, it is possible to shrink or enlarge objects indefinitely. However, this would require extreme conditions and may not be practical or feasible. Objects also have physical limitations, and at some point, they may break or undergo irreversible changes.
4. Can shrinking or enlarging objects affect their properties?
Yes, changing the size of an object can also affect its properties. For example, shrinking an object can make it stronger and more rigid, while enlarging it can make it more flexible. This is because the internal structure of the object is altered when its size is changed.
5. Are there any safety concerns when shrinking or enlarging objects?
Yes, there can be safety concerns when manipulating the size of objects. For example, if a gas is compressed to shrink an object, it can create high pressure and potentially cause explosions. It is important to follow proper safety procedures and have a thorough understanding of the materials and methods being used.
