Shunt Reactors for Voltage Control
In summary: The article goes on to say that, "the voltage sensitivity to changes at one busbar due to small changes in real and reactive power at another busbar can be determined from the stability analysis expression."What is the stability analysis expression?In summary, the stability analysis expression is a simplified expression that is quite accurate in most cases. It determines the voltage sensitivity to changes at one busbar due to small changes in real and reactive power at another busbar.
jegues
1,097
I was reading through an article on, "Shunt Reactors for Voltage Control" and I am slightly confused. (See link below for article)
http://www.onegrid.com.au/wp-content/uploads/2012/03/BR-EN-TH16-02_2006-Shunt_reactors_for_voltage_control.pdf
The article reads, "When the network load and particularly the high voltage network drops, the voltages on all the busbars increase due to the capacitive current in the transmission line."
It then goes on to say, "The voltage sensitivity to changes at one busbar due to small changes in real and reactive power at another busbar can be determined from the stability analysis expression."
[tex]dV_{i} = \frac{\partial V_{ij}}{\partial P} \dot dP_{j} + \frac{\partial V_{ij}}{\partial Q} \dot dQ_{j}[/tex]
"A simplified expression that is quite accurate in most cases is"
[tex]\Delta V_{i} = \frac{\Delta Q_{i}}{S_{SC}}[/tex]
What do they mean by capacitive currents, and how does that increase the voltage on the busbar?
How does adjusting the reactive power change the voltage levels?
AC power distribution systems have a very low output impedance so it is convenient to think of the AC voltage on the line as a reference.
A resistive load will cause a line current to flow that is in phase with the voltage. That is real energy flow. It is measured in watts, usually kW or MW.
A capacitive load will cause a current to flow that leads the voltage by 90°.
An inductive load will cause a current to flow that lags the voltage by 90°.
Those reactive currents do not transfer energy because the voltage times current is zero due to the phase shift. That is a circulating energy known as “Volts Amps Reactive” (VAR). Usually specified as kVAR or MVAR.
The circulating reactive current is the difference between the capacitive and the inductive currents. Ideally that will be close to zero so there will be no unnecessary circulating current.
The real current flowing on the line is the vector sum of the real and the reactive currents. It should have a phase angle close to the voltage reference.
There is a voltage drop due to the line's series resistance multiplied by the VAR, so it is taking a real amount of power to circulate the reactive current. The circulating current therefore influences the voltage magnitude since the line drop is in series with the supply.
Related to Shunt Reactors for Voltage Control
1. What is a shunt reactor?
A shunt reactor is an electrical device that is used in power systems to regulate and control the voltage. It is a type of inductor that is connected in parallel with the power transmission lines, and it helps to maintain the voltage levels within the desired range.
2. How do shunt reactors work?
Shunt reactors work by absorbing reactive power from the power system. This reduces the voltage level and helps to maintain it within the desired range. When there is an increase in voltage, the shunt reactor will absorb more reactive power and vice versa.
3. What are the benefits of using shunt reactors for voltage control?
Using shunt reactors for voltage control provides several benefits, including improved voltage stability, reduced power losses, and increased power system efficiency. Shunt reactors also help to mitigate voltage fluctuations due to varying loads and improve the overall reliability of the power system.
4. How are shunt reactors different from other types of voltage control devices?
Unlike other types of voltage control devices such as tap changers or static compensators, shunt reactors do not require any active control. They work passively by absorbing reactive power and do not require any external power source to function. This makes them a cost-effective solution for voltage control.
5. What are some key considerations when selecting and installing shunt reactors for voltage control?
When selecting and installing shunt reactors for voltage control, some key considerations include the voltage and current ratings, the physical location and space constraints, and the type of insulation and cooling system. It is also important to consider the potential impact on the power system and perform proper testing and maintenance to ensure optimal performance.
  • Electrical Engineering
  • Materials and Chemical Engineering
  • Electromagnetism
13K
  • Math Proof Training and Practice
21K
