Sidereal frame and conservative force.
In summary, a sidereal frame of reference is a reference frame which uses fixed stars as a frame of reference. It is more inertial than a laboratory frame.
Gwilim
126
Briefly describe a sidereal frame of reference, and then state Newton's laws of motion
I can't find sidereal in the index of my textbook, but my googling leads me to conclude that it's something to do with fixed stars. I'm not sure if a sidereal frame is also an inertial frame. Newtons laws are easy enough, but I get the feeling I'm not being asked for the classical formulations, but rather to append 'with reference to an inertial frame' or the like to the end.
State the properties satisfied by a conservative field of force, and then derive the energy equation for a particle of constant mass m moving under the influence of such a force
Umm, help?
Hi Gwilim! :smile:
"sidereal" simply means fixed relative to the stars …
it's more inertial than a laboratory frame!
(because it doesn't pretend that the Earth isn't spinning. :biggrin:)
Go on, start … what are the properties satisfied by a conservative field of force? :wink:
tiny-tim said:
Hi Gwilim! :smile:
So what would be acceptable wording in an exam?
"A sidereal frame of reference is one which uses fixed stars as a frame of reference"?
Seems a bit, uhh, self referential?
I don't know :( I hear it's something about 0 curl but I don't think I'm expected to know what curl is so that can't be the answer they're looking for. Can't you just tell me?:rolleyes:
FAQ: Sidereal frame and conservative force.
What is a "sidereal frame"?
A sidereal frame is a reference frame that is fixed with respect to the distant stars. It is used in astronomy and space science to measure positions and movements of celestial bodies.
How is a sidereal frame different from an inertial frame?
An inertial frame is a reference frame that is not accelerating or rotating, while a sidereal frame is fixed with respect to the distant stars. In other words, an inertial frame is a type of sidereal frame, but not all sidereal frames are inertial.
What is a "conservative force"?
A conservative force is a type of force that does not depend on the path taken between two points, but only on the initial and final positions. Examples of conservative forces include gravity and electrostatic forces.
How does a conservative force affect motion?
A conservative force causes changes in the potential energy of a system, which in turn affects the motion of objects within the system. The work done by a conservative force is independent of the path taken, so it does not dissipate energy as heat.
What are some examples of conservative forces?
In addition to gravity and electrostatic forces, other examples of conservative forces include magnetic forces, elastic forces, and the force of tension in a string. These forces conserve energy and do not dissipate it as heat.
17K
