Sign convention in the space-time 4-vector
In summary, the convention for scalar products of vectors in general relativity is to use (+,+,+,+) instead of the standard (+,+,+,-,). This choice arises from the geometrical structure of spacetime, and there is no cross-over with the metric. Tensor calculus is often necessary to understand the structure of a space-time manifold, and GR allows for more complex coordinate systems than classical physics.
redtree
330
What is the rationale for the sign convention in the space-time 4-vector? How is it related to the sign convention in the energy-momentum 4-vector, if at all?
It's all related to the norm or dot product of 4 vectors. The Lorentz group keeps the inner product [itex]v_0 w_0 - v_1 w_1 -v_2 w_2 ...[/itex] invariant. So start with a vector with components
[itex]v_\mu = (v_0, v_1,v_2, ... v_3)[/itex] and when you raise the index with the metric, you get [itex]v^\mu = (v_0, -v_1, -v_2, ... -v_3)[/itex].
Hope that helps.
I assume you mean, why do we write [itex]ds^2 = (cdt)^2 - dx^2 - dy^2 - dz^2[/itex] rather than [itex]ds^2 = dx^2 + dy^2 + dz^2 - (cdt)^2[/itex]?
For one thing, with this choice, we get a positive number for a "causally connectable" spacetime interval. Also, if we use the same convention for all four-vectors, then for energy-momentum [itex]E^2 - (p_x c)^2 - (p_y c)^2 - (p_z c)^2 = (m_0 c^2)^2[/itex] which is also a positive number.
We could do it the other way, but it seems to me that this way, we get fewer minus signs associated with the invariant quantities that we're usually interested in.
Relativists seem to prefer the latter, while field theorists seem to prefer the former. Which sucks when you're both a relativist and a field theorist =)
My real question is the following: why we don't use the standard convention for scalar products of vectors (+,+,+,+) in GR?
Because that's not what nature chose to give us. Also, you'll notice that there's no cross-over with that metric. In other words, there is no limiting speed like the speed of light.
Have you ever learned about tensor calculus? If you have brief understanding of tensor, the answer is obvious. This is because the metric ds squared equals to (ct) squared minus the sum of squares of (dx), (dy) and (dz).
That's not actually a "convention".
The signature arises from the geometrical structure of the space you are dealing with.
Often one deals with a Euclidean space... which is often implicit... but it's there.
In relativity, as others have pointed out, the geometrical structure of spacetime has a Lorentzian-signature metric tensor... with one sign different from the rest.
Whether it's (-,+,+,+) or (+,-,-,-) or (+,+,+,-) or (-,-,-,+) is the choice of convention. (It's not just the signs... it's also the use of x0 or x4. These days x0 is preferred to allow consideration of more or fewer spatial dimensions.) Pick your favorite, make it known, and use it consistently [and be prepared to translate if necessary].
Here is a book I would like to introduce you if you does not have strong enough background on tensor calculus. Schaum's outline series, theory and problems of tensor calculus by David C. Kay. This book is easy to follow and should be able to learn all the materials in it within a few weeks normally especially if you already have some knowledge of relativity.
Because it would require complex coordinates, which is pretty irritating! :smile:
Pete
FAQ: Sign convention in the space-time 4-vector
What is the sign convention in the space-time 4-vector?
The sign convention in the space-time 4-vector refers to the convention used to describe the direction and magnitude of a vector in space and time. It is used in special relativity to represent four-dimensional spacetime, where the first three dimensions represent space and the fourth dimension represents time.
What is the significance of the sign convention in the space-time 4-vector?
The sign convention in the space-time 4-vector is significant because it allows for the consistent representation of events in space and time. It helps to describe the relationship between space and time and enables calculations in special relativity to be performed accurately.
How is the sign convention represented in the space-time 4-vector?
The sign convention is represented by the use of plus and minus signs in the components of the vector. The first three components represent the spatial dimensions and are denoted by x, y, and z, while the fourth component represents time and is denoted by ct, where c is the speed of light. A positive sign indicates motion in the positive direction, while a negative sign indicates motion in the negative direction.
Are there different sign conventions used in the space-time 4-vector?
Yes, there are two common sign conventions used in the space-time 4-vector. The first is the Minkowski or (-,+,+,+) convention, which is commonly used in theoretical physics and relativity. The second is the mostly plus or (+,-,-,-) convention, which is commonly used in particle physics and cosmology. Both conventions are valid and can be used in calculations, but it is important to be consistent within a specific context.
How does the sign convention affect the interpretation of the space-time 4-vector?
The sign convention does not affect the interpretation of the space-time 4-vector. The interpretation remains the same regardless of which convention is used. However, the sign convention does affect the numerical values of the components in the vector and the resulting calculations. It is important to be aware of the sign convention being used in order to interpret the results accurately.
