Signals & Systems - De Moivre's question
In summary: The Kronecker delta function, denoted as δ[n], is defined as 1 when n = 0 and 0 otherwise. So, δ[n] = 1 when n = 0 and δ[n] = 0 when n ≠ 0. When n = 0, δ[n-1] = δ[-1] = 0. So, δ[n-1] = 0 when n = 0 and δ[n-1] = 0 when n ≠ 0. This is why δ[n] is 1 and δ[n-1] is e^(-j*Omega/2).
Angello90
65
From the lecture notes:
[tex]h[n] = \frac{1}{2}(\delta[n] + delta[n-1])[/tex]
via property:
[tex]H(e^{j\Omega})=\sum_{-\infty}^{\infty}h[k]e^{-j\Omega k}[/tex]
becomes:
[tex]H(e^{j\Omega})= \frac{1}{2}(1 + e^{-j\Omega})[/tex]
than my lecture divided by [tex]e^{\frac{-j\Omega}{2}}[/tex] resulting in:
[tex]H(e^{j\Omega})= e^{\frac{-j\Omega}{2}}[(e^{\frac{j\Omega}{2}} + e^{\frac{-j\Omega}{2}})/2][/tex]
Now he changed [tex](e^{\frac{j\Omega}{2}} + e^{\frac{-j\Omega}{2}})/2[/tex] to [tex]cos(\frac{\Omega}{2})[/tex]
How? Can anyone explain me? Also why [tex]\delta[n][/tex] is 1 but [tex]delta[n-1][/tex] is [tex]e^{\frac{-j \Omega}{2}}[/tex]?
via property:
becomes:
No, he didn't divide by e^(-j*Omega/2). He factored it out of the two expressions in the parentheses. If you multiply the two expressions in parentheses in this equation, you'll get right back to what's in the equation above.
This is an identity. (1/2)(e^(ix/2) + e^(-ix/2)) = (1/2)[cos(x/2) + isin(x/2) + cos(-x/2) + isin(-x/2)] = (1/2)[2cos(x/2)] = cos(x/2).
This is using the identities cos(-a) = cos(a) and sin(-a) = -sin(a).
FAQ: Signals & Systems - De Moivre's question
What is De Moivre's question in signals and systems?
De Moivre's question in signals and systems is a mathematical concept that deals with complex numbers and their representation in polar form. It asks how to find the nth root of a complex number.
What is the importance of De Moivre's question in the field of signals and systems?
De Moivre's question is important in signals and systems because it helps in solving problems related to complex numbers and their representation. It is also used in analyzing and understanding the behavior of systems in the frequency domain.
How is De Moivre's question related to the Fourier series?
De Moivre's question is closely related to the Fourier series as it helps in finding the complex coefficients of the series. It is used in converting a time domain signal to its frequency domain representation.
Can De Moivre's question be used in real-life applications?
Yes, De Moivre's question has many real-life applications, especially in engineering and physics. It is used in signal processing, control systems, and circuit analysis, among others.
Are there any limitations to De Moivre's question?
De Moivre's question has certain limitations, such as it can only be applied to linear systems and it assumes that the system has a steady-state response. It also requires the use of complex numbers, which can be challenging for some people.
