Significance of band gap in k-space
In summary: The band diagram should be used only as a guide for what the band gaps are and an estimate of the carrier lifetime.
NaOH
31
I am struggling in understanding what the band structure (E vs. k) diagram tells me.
Let's say I have the following material:
http://www2.warwick.ac.uk/fac/sci/physics/current/postgraduate/regs/mpags/ex5/phonons/indirect_absorption/indirect_absorption.bmp
Let the direct band gap be denoted as ωg. Let's say the temperature is such that it is possible for energies up to ħ(ω+Ω). But since ε(ħ(ω+Ω))<ε(ωg), can I say that I will only observe appreciable current when I apply a electric field in the direction of +kr?
There is something weird about that diagram. ħω is an energy transition, but the lateral transition is a MOMENTUM transition, not energy. So the units/dimensions are all wrong.
In an indirect transition, you need a momentum change to achieve that transition. So just simply adding energy, such as in the form of heat, will not achieve such a transition. It will require a momentum transfer, usually from phonon exchange, to provide such a momentum transition.
All your band diagram is showing is that the conduction band minimum is not at the same momentum vector as the valence band maximum. So to cause a transition from the valence band maximum to the conduction band minimum, you need energy and momentum change.
Zz.
It is a standard diagram for indirect absorption assisted by phonon emission, but it should never ever be quoted out of context like here. The photon energy [itex]\hbar \omega[/itex] equals the sum of the indirect band gap energy and the phonon energy [itex]\hbar \Omega[/itex]. The photon essentially contributes all the energy and negligible momentum. The phonon essentially contributes all the momentum and negligible energy. The momenta are not shown explicitly, but are explained in the accompanying text That would have been clear if the OP had cited the whole page including the explanation instead of just the picture.
That is a bit puzzling. You seem to be interested in questions of transport (current and conductivity and stuff), while the diagram is mainly of interest when discussing the indirect band gap from an optics point of view. As ZapperZ already pointed out, phonon assisted processes are already sufficient for realizing such an indirect transmission.
Please note that the main interesting thing about indirect semiconductors is something different. If you have enough thermal energy for electrons to make the direct band gap transition, but there is an indirect band gap of lower energy nearby in momentum space, electrons in the conduction band will relax to that energy minimum of the conduction band quite quickly. From there, they cannot directly recombine and go back to the valence band just by photon emission. An additional phonon is required. As these phonon assisted processes are way more improbable than the direct transition, the carrier lifetimes are typically much larger in indirect band gap semiconductors like silicon compared to semiconductors with a direct band gap.
Thank you for the responses. It helped clarified some doubts which I had about the concept.
I asked this question to my professor (albeit in less detail) last semester when I had my intro to solid state physics course but he kinda gave the 'I don't know where you are coming from' look so I did not probe further. I think I understand where this look he is having comes from now.
I hope I am not complicating the problem too much by shifting our attention to yet another band structure (SiC):
http://www.ioffe.rssi.ru/SVA/NSM/Semicond/SiC/bandstr.html
How I see it is that the promotion of electrons from the valance to conduction band would generate the charge carriers for current. The band structure is that of energy versus wavevector of the electrons. In SiC, then, it seems to me like an indirect transition would require 2.36 eV but these electrons will only be in the <100> direction. If we have a perfect crystal, then supplying only ~2.36eV will only allow for appreciable electrons to flow in the <100> direction, while the holes basically are free to go where they want. Can I interprete the diagram like this? Or should the band diagram be used only as a guide for what the band gaps are and an estimate of the carrier lifetime?
Related to Significance of band gap in k-space
What is the band gap in k-space?
The band gap in k-space is a concept in solid state physics that refers to the energy difference between the highest energy level of the valence band and the lowest energy level of the conduction band. It is a measure of the energy required for an electron to transition from the valence band to the conduction band.
What is the significance of the band gap in k-space?
The band gap in k-space is a key factor in determining the electrical and optical properties of a material. It affects the conductivity, resistivity, and optical absorption of a material, making it a crucial parameter in the design and development of electronic devices.
How is the band gap in k-space calculated?
The band gap in k-space can be calculated using various theoretical models, such as the Kronig-Penney model or the nearly free electron model. These models take into account the crystal structure and the energy levels of the material to determine the band gap. Experimental techniques, such as optical absorption and photoemission spectroscopy, can also be used to measure the band gap.
What factors influence the band gap in k-space?
The band gap in k-space is influenced by several factors, including the crystal structure and composition of the material, temperature, and external electric and magnetic fields. Additionally, the band gap can be tuned by doping the material with impurities or by applying strain to the crystal lattice.
What are the practical applications of understanding the band gap in k-space?
Understanding the band gap in k-space is crucial for the development of electronic devices, such as transistors, solar cells, and light-emitting diodes. It also plays a key role in materials science and engineering, as the band gap can determine the properties and behavior of materials in various applications, such as energy storage, optoelectronics, and semiconductors.
  • Atomic and Condensed Matter
11K
10K
