Significance of nonvanishing gradient
In summary, the assumption that the gradient of a surface is not equal to the zero vector is necessary in discussing the properties and behavior of surfaces expressed as F(x,y,z). It allows for the definition and calculation of tangent planes and the intersection of surfaces, and ensures that the surface is well-defined and not simply a flat, infinitely thin plane.
Syrus
214
I am working in "Intro to PDEs with Applications" on page 6. Gradients come up in discussions of surfaces expressed as F(x,y,z). In discussing such matters, the buildup includes the assumption that grad F is not equal to the zero vector. A later line reads, "Under the assumption [above], the set of points (x,y,z) in the domain which satisfy the equation F(x,y,z) = c for some appropriate value of c, is a surface is the domain.
My question is, what precautions does the gradient not being zero entail? The only answer I've been able to come up with so far is that they mean smooth surface when they simply say surface (since points where grad F = 0) seem to correspond to 'corners' or non-differentiate points. Any deeper or more accurate insight?
If you have a gradient of zero over an extensive region, it allows for ## F(x,y,z) ## being constant throughout that region. In this case setting ## F(x,y,z)=c ## and finding the points ## (x,y,z) ## will not define a "infinetesimally thin" surface, but rather the set of points could consist of something of finite thickness in places where the gradient is zero.
All a gradient does is point in the direction of max increase for a given function. Therefore, a function that has no point anywhere with a gradient equal to zero simply means there is no peak, no local or absolute maximum in other words.
None of what you guys said attests as to why you couldn't have a "surface" with those properties. Link- I've never heard of "thickness" as a consideration of surfaces- but then again- how does this take away from the SURFACE aspect of it? Gilb- who cares if there's no local or absolute minima or maxima? A surface doesn't need any (e.g. a horizontal plane).
I misunderstood your question then. Think about it like this. Define the axis for your surface in Cartesian coordinates. Now try thinking up any finite, non-infinite, surface that never switches from having an upward curve to downward curve. One that never peaks. The only possibility is a flat horizontal surface.
Also what are you taking the gradient of? Density? Height? Temperature? I sort of assumed height in my prior post.
It's just the gradient of an arbitrary surface F(,x,y,z). Not necessarily a function.
You can only take the gradient of a scalar field, therefore a function. It has to be a function of something. In the example of F(x,y,z) what you would typically be taking the gradient of is z by defining a new function (if you were trying to just take the gradient of the surface itself, think of a contour map in this case).
Without actually seeing the full context of the text, what this seems to be referring to is that for the gradient of a function of three variables, every set of points that shares the same gradient value forms a surface (just like for a function of two variables, every set of points that shares a gradient forms a contour). Is this what you were asking for clarification on?
TJGilb said:
Without actually seeing the full context of the text, what this seems to be referring to is that for the gradient of a function of three variables, every set of points that shares the same gradient value forms a surface. Is this what you were asking for clarification on?
I think the thing that defines the surface here is the set of points ## (x,y,z) ## such that ## F(x,y,z)=c ## where ## c ## is a constant. The gradient ## \nabla F(x,y,z) ## points normal to the surface at any point and will normally vary in amplitude and direction over the whole surface.
I guess what I'm trying to ask is why is the assumption that grad(F) is nonzero necessary in the ensuing discussions? The text goes on to discuss topics such as using grad to find equations of tangent planes to surfaces and (eventually) to prove that a curve can result as the intersection of two surfaces (by saying grad F1 X grad F2 is also nonzero.
As I previously responded, the gradient being non-zero is a sufficient (probably not necessary, but sufficient) condition to create a well-defined surface. If the surface has a finite thickness, then where is the surface precisely located, i.e. what is the z for a given x and y? It would not be precisely defined if the thickness was finite.
Well, a gradient of zero ##\nabla f = f_x\hat x +f_y\hat y +f_z\hat z = 0## means that each component is zero, ie the zero vector. If you were to take the cross product of two zero vectors, or any vector with a zero vector for that matter, what do you get? Zero. It defeats the purpose of a cross product in this case, which is to get a new vector orthogonal to both.
Likes Charles Link
Charles Link- I think I understand what you're saying, but let's consider the cone given by F(X,y,z) = z^2-x^2-y^2 = 0. Grad F = 0 at (0,0,0). But this seems to have nothing with the concept you're talking about- or does it?
It all depends on what you're trying to do with the gradient. There's nothing inherently preventing the gradient from being zero, but it's just not a very valuable for the types of applications it looks like your book is talking about. After all, there is only one point on that surface with a zero gradient, which certainly isn't a curve, and you won't be finding any tangent planes with it.
I'm also not finding any sources on the gradient being sufficient to have a well-defined surface. Any references for this?
That depends on what function you're taking the gradient of. The gradient of a function of three variables can be divided into a set of surfaces, where each surface represents every point that shares the same gradient magnitude. If it was a function of two variables, instead of being divided into a set of surfaces, it would be a set of curves.
Oh and the gradient can serve as a normal vector with which to find a tangent plane at any point (assuming it's nonzero).
Well put, I assume that is why they made that assumption- so the ensuing discussion applied to all points considered (as long as grad F is nonzero).
Look up the "Implicit Function Theorem".
Having a nonzero gradient vector at ##(x_0,y_0,z_0)## means that at least one of the partial derivatives is nonzero. For example, if ##F_z(x_0,y_0,z_0)
\neq 0##, then ##dF = 0 = F_x dx + F_y dy + F_z dz## can be solved for ##dz## in terms of ##dx## and ##dy## (because we are allowed to divide by ##F_z \neq 0##):
$$ dz = -\frac{F_x}{F_z} dx - \frac{F_y}{F_z} dy.$$
That implies that for ##(x,y)## near ##(x_0,y_0)## we have ##z = f(x,y)## for some smooth function ##f(x,y)##. In other words, if ##F_z \neq 0## the equation ##F(x,y,z) = 0## leads to a unique expression for ##z## as a smooth function of ##(x,y)##, and the function is unique, at least near ##(x_0,y_0,z_0)##.
If the gradient vanishes, we may have a non-smooth and non-unique function (that is, two or more functions ##f_1(x,y)## and ##f_2(x,y)## which can also be non-smooth), or sometimes we can have several different smooth functions ##z = f_i(x,y)## that all satisfy ##0 = F(x,y,f_i(x,y))##. Alternatively, we may have no such functions at all; it all depends on details about the nature of the original function ##F##.
The cone is a well-defined surface. An isolated point where the gradient is zero will have little effect. I don't have a whole lot more to provide other than to say in the case of the gradient being zero over an extended range would make the calculations your textbook does non-applicable. In an advanced calculus course quite a number of years ago the mathematics professor did tell us there are entire books written about how surfaces are defined. For most practical applications, it is not necessary to study this concept in such depth, but just a common sense approach should give you most of what you need.
For ##F(x,y,z) = z^2-x^2-y^2,## the fact that ##\nabla F = (0,0,0)## at ##(x,y,z) = (0,0,0)## means that the standard theorems about existence of a unique smooth surface ##z = f(x,y)## through ##(0,0,0)## are violated. There are two different surfaces ##z = \sqrt{x^2+y^2}## and ##z = - \sqrt{x^2+y^2}##, and both of them happen to be non-smooth (lacking continuous derivatives at ##(x,y) = (0,0)##).
Likes Charles Link
Ray- you're absolutely correct- the implicit function theorem is in fact discussed and I believe both your points apply here
Related to Significance of nonvanishing gradient
What is the significance of nonvanishing gradient?
The nonvanishing gradient is a crucial concept in gradient-based optimization algorithms used in machine learning and deep learning. It refers to the scenario where the gradient of the cost function does not approach zero, which indicates that the model is still learning and improving.
Why is the nonvanishing gradient important in machine learning?
The nonvanishing gradient indicates that the model is still learning and has not reached a local minimum, which is necessary for the model to continue improving and achieving better performance. It also helps prevent the model from getting stuck in a plateau or a local minimum.
What causes the gradient to vanish?
The gradient of the cost function can vanish due to various factors, such as using a shallow network, using a large learning rate, or using an activation function that saturates. In these cases, the gradient becomes close to zero, and the model stops learning and improving.
How can the issue of vanishing gradient be addressed?
The issue of vanishing gradient can be addressed by using techniques such as gradient clipping, using different activation functions, or using alternative optimization algorithms such as Adam or RMSprop. These methods can help prevent the gradient from vanishing and allow the model to continue learning.
Does the nonvanishing gradient always indicate good performance?
No, the nonvanishing gradient does not always indicate good performance. It is possible for the gradient to remain nonvanishing, but the model may still not perform well due to other factors such as poor data quality, overfitting, or incorrect hyperparameter settings. Therefore, it is important to consider other metrics and perform thorough analysis to evaluate the performance of a model.
