Significant Figures in long physics calculations?
In summary: Newbie here. Forgive if I'm starting this thread in the wrong place! Started college physics this semester and although the physics is not the most challenging, I'm running into lots of trouble with the sig figs! First of all, when doing long calculations, where do you round the sig figs? Just a quick problem: Plane in the wind, heading south at 185 km/hr, after an hour the place has only gone 135 km at 15 degrees East of South. I know how to do this, but I ran into trouble with the first part in finding the Southern displacement.cos(15)*135 = southern displacement.Does this equation equate to 2 significant figures because of cos(15)?
atkin
Hi all,
Does this equation equate to 2 significant figures because of cos(15)? Or is it 3 from 135?
Another example that I had trouble with is a question about finding where a long jumper will land. I found the initial velocity, used that to find how long the jumper was in the air with Vi, and solved for t with the quadratic equation. But, again, the sig figs are haunting me. Should I round them when I find the initial velocity and then use the rounded velocity in the quadratic equation? Or should I use the raw initial velocity in the quadratic equation, then round after? I am thoroughly confused with this, because then I don't know where in the quad formula to round!
If someone could clear this up I would REALLY appreciate this. I am normally an A+ student but my grades are suffering because of the sig fig confusion. Again, I thank you so much if you can help even guide me in the right direction.
(EDIT) I am not asking for any of my homework to be solved. I can complete it, just the sig figs part I don't know where to start!
My general suggestion is to keep everything symbolic and only plug in numbers at the very end. Never round things off in the middle of a computation.
In the end, significant digits are a bit of a poor man's error propagation and I do not think teachers should be too strict with applying arbitrary rules on how many significant digits should be included as long as it is reasonable. For example, the numbers 1.3 and 9.4 imply very different relative errors even though they have the same number of significant digits.
I agree with Orodruin. Ideally, you should get a single equation that gives you the final answer, then plug all your given numbers into that, calculate the answer in one fell swoop on your calculator, and round off that final answer.
If the algebra is too cumbersome for that method, you can break up the calculation into separate steps. Or you may be given a problem that's already divided up into separate steps that you have to give the intermediate answers for (parts a, b, c, etc.) In that case, you should leave the answer for each step in your calculator to use as input for the next step, unrounded. If you need to give that number as an answer to a sub-part of the problem, round it off when writing it down, but leave the unrounded version in the calculator.
In general, the trig functions and other functions and constants like pi have been calculated to many more decimal places than are practical for most calculations (anything beyond about 9-10 places is just showing off), so these ordinarily do not limit the precision of a calculation. It's usually other data, which has to be physically measured or estimated, which provide the limiting precision of a result.
Note: if you are required to report intermediate results, report them with a correct number of sig figs, but use as many as you have for the further calculations.
This is the first time I see someone reporting serious problems with sig figs in the context of physics course. Chemists often treat them with a divine attention, but physicist are fully aware they don't matter much.
Related to Significant Figures in long physics calculations?
1. What are significant figures and why are they important in physics calculations?
Significant figures are digits in a numerical value that represent the precision of a measurement or calculation. They are important in physics calculations because they indicate the level of accuracy and reliability of the results.
2. How do I determine the number of significant figures in a given value?
The rule for determining significant figures is to count all non-zero digits and any zeros between non-zero digits. Trailing zeros after a decimal point are also significant. Leading zeros and placeholder zeros are not significant.
3. What is the significance of rounding when dealing with significant figures?
Rounding is necessary in order to properly represent the level of precision in a calculation. When rounding, the final answer should have the same number of significant figures as the least precise value used in the calculation.
4. Can significant figures be used in algebraic equations?
Yes, significant figures can be used in algebraic equations. The final answer should have the same number of significant figures as the least precise value used in the equation.
5. How do I handle addition and subtraction with significant figures?
When adding or subtracting values with different numbers of significant figures, the final answer should be rounded to the least number of decimal places in any of the values. This ensures that the final answer does not have more significant figures than the least precise value.
  • Other Physics Topics
