Semiconductor Energy Gap: Silicon Explained
In summary, the conversation discusses the energy gap of silicon as a semiconductor and the possibility of it becoming a conductor under certain conditions. An image is referenced to show the relationship between interatomic distance and the energy gap, and the question is raised about whether this means silicon can become a conductor. The conversation concludes by mentioning the potential for semiconductors to change into conductors under certain circumstances.
alphard
Hello everyone,
I have a quick question about the energy of the silicon. I know that, as a semiconductor, the silicon has an energy gap between the valence band and the conduction band. But according to this image , http://www.google.fr/imgres?imgurl=http%3A%2F%2Fwww.nano-ou.net%2FImages%2Fsilicon_split.png&imgrefurl=http%3A%2F%2Fwww.nano-ou.net%2FeduNanomaterials2.aspx&h=443&w=665&tbnid=lroOZttxuLz6EM%3A&zoom=1&docid=bVNjJ0Q6l2ncJM&ei=IW8MVYGONYPYOJ-ygeAO&tbm=isch&iact=rc&uact=3&dur=1859&page=1&start=0&ndsp=25&ved=0CCQQrQMwAQ , we see that when the interatomic distance between two atoms of silicon decreases, there is an interval where there is no more "forbidden energy gap" (where the two grey curves are connected). Does that mean that at this point, we have a conductor and not a semiconductor anymore ? I mean, by definition, a semiconductor has an energy gap, not as large as an insulator, but the gap exists. So, without any gap, it should by a conductor.
Thanks for your answers
Well I am not sure, but there are semiconductors that when are exposed to mechanical strains, or other types of lattice distortions, their band structure changes, and sometimes they transit from semiconductors to conductors. So yes, you can have a material that is a semiconductor in normal conditions and become a conductor under certain conditions.
Related to Semiconductor Energy Gap: Silicon Explained
1. What is a semiconductor energy gap?
A semiconductor energy gap is the energy difference between the valence band and the conduction band in a semiconductor material. It is the minimum amount of energy required for an electron to move from the valence band to the conduction band and become a free charge carrier.
2. How is the energy gap of silicon determined?
The energy gap of silicon is determined by its crystal structure and the arrangement of its atoms. Silicon has a diamond crystal structure, which results in a relatively large energy gap of 1.1 electron volts (eV).
3. Why is silicon commonly used as a semiconductor material?
Silicon is commonly used as a semiconductor material because it is abundant, has a well-defined energy gap, and is easily processed into electronic devices. It also has good electrical and thermal properties, making it suitable for a wide range of applications.
4. How does the energy gap affect the conductivity of silicon?
The energy gap of silicon affects its conductivity because it determines the amount of energy required for electrons to move from the valence band to the conduction band. A larger energy gap means that fewer electrons can easily move, resulting in lower conductivity. This makes silicon a good semiconductor material as it can be easily controlled and manipulated to switch between conducting and non-conducting states.
5. Can the energy gap of silicon be changed?
Yes, the energy gap of silicon can be changed by altering its crystal structure or by adding impurities, a process known as doping. Doping can either increase or decrease the energy gap, making it possible to tailor the properties of silicon for specific applications.
