Silvaco: "simulator has unexpectedly exited with status -1073741819"
The user is encountering an error with Silvaco's simulator during the NMOS construction process, specifically at the last implantation stage. Despite attempts to adjust the implantation energy and dose, as well as changing the project folder and including thermal annealing, the issue persists. Previous similar errors were resolved by changing the tony plot version, but this situation does not relate to that. A suggestion was made that the error might be an access violation caused by a buffer overrun, and contacting Silvaco for support was recommended. The discussion highlights the need for troubleshooting assistance with the simulator's unexpected exit status.
mohamis288
TL;DR Summary
it is about an error in Silvaco software.
the error is here: "simulator has unexpectedly exited with status -1073741819"
this error occurs when I wanted to make the source and drain implantation.
Hello,
I am simulating the process of NMOS construction. as you know, in order to make the LDD, we need two implantations, one before creating oxide spacer and another after creating oxide spacer. at the last implantation, I am facing an error which is shown in the following image:
I put the code in the attachment too. I have placed thermal annealing after each implantation. Also, the project folder has been changed a couple of time to see the problem is solved or not. energy and dose of implantation has been changed in a wide range, but it did not help. actually, such error has been previously seen in this software but that was when tony plot wanted to come up. in mentioned condition, we just changed the tony plot version in the preference window, and this was solved. but now, this error is not about tony plot, because it even does not complete running Athena codes.
SO, have you any opinion to solve this error?
any help would be appreciated.
BR
Probably an access violation error caused by a buffer overrun.
Could be this answer is completely useless, but that's what Visual Studio documentation says about error 0xC0000005.
I'd suggest contacting Silvaco.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
