MHB Similar Matrices: Are Eigenvalues the Same?
If matrices A and B are similar, they share the same eigenvalues, but the converse is not necessarily true. An example demonstrates that matrices can have the same eigenvalue without being similar. Specifically, while matrix A has a repeated eigenvalue of 1, matrix B has eigenvalues of 1 and -1, showing they are not similar. Additionally, matrix C shares the same repeated eigenvalue with A but is also not similar to it. Thus, having the same eigenvalues does not imply similarity between matrices.
Sudharaka
MHB
saravananbs's question from Math Help Forum,
if A and B are similar matrices then the eigenvalues are same. is the converse is true? why?
thank u
Hi saravananbs,
No. The converse is not true in general. Take the two matrices, \(A=\begin{pmatrix}1 & 0\\0 & 1\end{pmatrix}\mbox{ and }B=\begin{pmatrix}0 & 1\\1 & 0\end{pmatrix}\).
\[\begin{pmatrix}1 & 0\\0 & 1\end{pmatrix}\begin{pmatrix}1 \\ 1\end{pmatrix}=1.\begin{pmatrix}1 \\ 1\end{pmatrix}\]
\[\begin{pmatrix}0 & 1\\1 & 0\end{pmatrix}\begin{pmatrix}1 \\ 1\end{pmatrix}=1.\begin{pmatrix}1 \\ 1\end{pmatrix}\]
Therefore both matrices have the same eigenvalue 1. However it can be easily shown that \(A\mbox{ and }B\) are not similar matrices.
Mathematics news on Phys.org
Hi saravananbs,
That example does not really work, because $A$ and $B$ do not have the same eigenvalues: $A$ has a (repeated) eigenvalue 1, whereas the eigenvalues of $B$ are 1 and –1.
However, if $C = \begin{pmatrix}1 & 1 \\0 & 1\end{pmatrix}$, then $A$ and $C$ have the same eigenvalues (namely 1, repeated), but are not similar.
Thanks for correcting that. Of course I now see that only the eigenvalue 1 is common to both \(A\) and \(B\).
Seemingly by some mathematical coincidence, a hexagon of sides 2,2,7,7, 11, and 11 can be inscribed in a circle of radius 7. The other day I saw a math problem on line, which they said came from a Polish Olympiad, where you compute the length x of the 3rd side which is the same as the radius, so that the sides of length 2,x, and 11 are inscribed on the arc of a semi-circle. The law of cosines applied twice gives the answer for x of exactly 7, but the arithmetic is so complex that the...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
Fermat's Last Theorem has long been one of the most famous mathematical problems, and is now one of the most famous theorems. It simply states that the equation $$ a^n+b^n=c^n $$ has no solutions with positive integers if ##n>2.## It was named after Pierre de Fermat (1607-1665). The problem itself stems from the book Arithmetica by Diophantus of Alexandria. It gained popularity because Fermat noted in his copy "Cubum autem in duos cubos, aut quadratoquadratum in duos quadratoquadratos, et...
